my non working clutch...
Old Jun 2, 2012 | 12:13 PM
Michael21's Avatar
Car: 1984 Trans am
Engine: 305 H.O.
I have installed the release slave/cylinder, and my dad and i have bled it a bunch of times, no air is coming out, but can't get the car to go into gear when running. Just wondering if anyone ekse has had this happen or if anyone has any ideas about what to do. Thanks in advance.
Old Jun 2, 2012 | 12:18 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: my non working clutch...
V8 T5?
Any pictures of the parts?
Rundown of parts like "used hydraulics, new master cylinder, used clutch and flywheel from 91 Z28" ??
Did the fork and it's spring clip go in the SAME groove on the throwout bearing?
Pilot bearing / bushing installed to back of crank?
Old Jun 2, 2012 | 12:25 PM
pvr007's Avatar
Car: 88 RS Camaro,70 chevelle,92 Geo
Engine: 305 TBI
Transmission: 5 Speed Manual
when bleading it helps to push the cilinder.. the bleeading screw is always close to the inline... so the air inside the cilinder doesnt get pushed out unless you push the cilinder
Old Jun 2, 2012 | 12:47 PM
Old Jun 2, 2012 | 02:01 PM
jmd's Avatar
jmd
I'd been meaning to talk to you about how far off centre the spring clip happens to be in the "correct" portion.
Old Jun 2, 2012 | 02:34 PM
Yeah I think whoever took that pic, they just jammed the TOB as far into the fork as it will go... that part is not quite right. But it shows the malfunction of "clipping" the spring onto the back of the groove, at least.
Old Jun 3, 2012 | 09:20 AM
Michael21's Avatar
Car: 1984 Trans am
Engine: 305 H.O.
I'm lost.....all that stuff is fine. Changed the engine last fall. Hmmmm, what if i start it IN gear??
Old Jun 3, 2012 | 10:23 AM
Inability to shift into gear = clutch not releasing
The malfunction in the pics will create that. It's the SINGLE MOST COMMON cause of this, when it fails right after being worked on but was OK before. I'm guessing you popped the trans out last night and checked?
About the only other things are, the clutch gear fits too tight in the pilot bushing (if you used a bushing), or, the fork isn't on the ball stud properly.
Starting the car in gear won't fix the clutch.
See my signature for a helpful mental outlook on troubleshooting things of this nature. Basically, it tells you to eliminate complicated convoluted "explanations" like space alien visitations, unheard-of newly invented failures of parts that never break, Friday night McDonalds parking lot monkey-spank, and the like; and instead, concentrate on looking for some one single simple thing that can account for ALL OF the observed symptoms, while leaving NONE un-accounted-for.
Old Jun 4, 2012 | 04:06 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
Have you checked to see if the clutch fork is moving when you step on the clutch pedal? If it is how much? If it seems to be full movement (about an inch or more) then I would check the fork pivot ball stud and make sure it is screwed in tight. A loose one will cause only partial disengagement leaving you to feel the clutch isn't releasing at all. This takes two people to check.
Remember that if you can truely say that everything mentioned is good then you most likely do not have a problem. Otherwise it is probably something that you have overlooked for whatever reason. Sofakingdom is right in that it is a clutch problem of sorts and that it will not usually be something highly unusual.
Clear your head and start rechecking everything with an open mind.
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
