Which Flywheel for t-5?
Car: 85 camaro z28
Engine: 355
Transmission: t-5
getting my engine swap done, the 305 was a 2 peice main seal, and the 355 going in is a 1 piece main seal, which flywheel should i get that is compatible for the t-5?
Car is an 85.
Car is an 85.
Car: 85 camaro z28
Engine: 355
Transmission: t-5
Re: Which Flywheel for t-5?
So this would work fine?
86-87 305 VIN H 4050013 Flywheel
http://www.hawksthirdgenparts.com/ca...placement.aspx
Yes it will work, except that will be the heavy one, since it's for the low-perf LG4 motor (VIN H).
Get the one for a VIN F (305 TPI) for any year from 86 to 92.
Car: 85 camaro z28
Engine: 355
Transmission: t-5
Car: 1991 R7U Z28 1LE
Engine: LB9
Axle/Gears: G92 3.42 Truetrac
Hi Sofakingdom: you have some great posts! I have a low mileage 86 LG4 stick so I have been memorizing your recommendations if I ever decide to mess with it. It's so tempting to hotrod an immaculate survivor......I already have the manifolds and the dual snorkel air cleaner on the shelf!
Just to clarify, do the 1986 engines have the distinction of having the one-piece rear main and counterweighted flywheel but didn't get the roller cam introduced in 1987.....right?
Car: `86 SS / `87 SS
Right. '86-up cranks are 1pc. rear main seal but the blocks still aren't factory-roller-cam provision equipped.
Exactly: 86 is a kind of "oddball" year. 1-pc RMS, but perimeter-bolt valve covers, no roller apparatus, and old-bolt-pattern intake.
Thanks for the good word BTW.
You'll find that there's certain people around here that KNOW these cars inside and out (I'd put jmd squarely in that group for example), some that are more experienced than others but haven't seen all there is to see, and some that are just getting going good... each adds some unique perspective to the hobby. The trick is, determining which is which.
monte87cortez
Sep 26, 2015 08:10 PM
