iroc wont shift unless..
Old Jul 17, 2012 | 12:36 AM
jeff_blake's Avatar
Car: 86 Iroc + 83 Firebird
Engine: Iroc 305 TPI, Firebird 305 4bbl
Transmission: 700r4 in both.
Axle/Gears: Iroc 3.27 Firebird 3.23
on my 86 iroc, with a 305tpi. the transmission will only shift around6-7k rpm only if u let off the throttle then get on it again, its like that in almost all gears.any ideas? tv/kickdown cable or anything? wasnt doing this befor it sat for awhile
Old Jul 17, 2012 | 03:09 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: iroc wont shift unless..
Definitely start by checking the tv cable, and make sure the fluid level is correct. "Sitting for a while" and shifting at 7K doesn't sound like a great recipe.
Old Jul 17, 2012 | 05:46 AM
Sounds like the tach is WAY off, as usual...
And of course, it has the trans problem as well.
Old Jul 17, 2012 | 05:58 PM
jeff_blake's Avatar
fluid levels are great, tach matches the same rpms as on my scanner.and the thing screams, then shifts. adjusting tv cable later on, hopefully fixes it.
Old Jul 19, 2012 | 12:25 AM
warriorcustoms's Avatar
Setting is hard on em & things stick Change the trans fluid & filter Then put a bottle of Lucas trans fix in it Top off with good trans fluid & go drive it Preferably where you can start & stop romp on it 4L60E trans will do that too when setting Rompin on it will unstick stuff
Old Jul 19, 2012 | 01:13 AM
jeff_blake's Avatar
i did put a new trans filter and gasket, with some valvonline dex 3 in there, fluid is still full. might try some trans fix though. curious.. the 700r4's if im not mistaken dont have the vaccum modulator? or what did they use in place of that if anything.
Old Jul 19, 2012 | 05:43 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
No vac modulator, tv cable instead.
Old Jul 19, 2012 | 08:38 AM
400 turbos had the vac modulator & some website sells a kit for the 700R4/4L60E if I remember right Been awhile since I built a 700R4 lol Try the Lucas trans fix If that doesnt work I will ask my buddy that does transmissions every day
Old Jul 19, 2012 | 10:19 AM
IROCZ28dan's Avatar
Car: 1987 IROC-Z
700R4 has a centrifugal governor to control shift rpm. If the engine is down on power the transmission will not shift properly. I had a fuel pump that lost pressure around 4800 rpm and that is where the vehicle would stay when at full throttle in first gear, until i lifted just slightly, then it would bang into 2nd. A few fuel pump that provided proper pressure consistantly fixed the issue. I would stay away from the lucas stuff, it doesn't do nice things to the inside of a transmission, its more of a used car dealer quick fix item.
Old Jul 29, 2012 | 01:07 AM
jeff_blake's Avatar
now the tv cable wont click when i tried adjusting it, and the lack of power occured the day the tranny wouldnt shift, wouldnt even chirp the tires, even if you tried.
Old Aug 5, 2012 | 06:52 AM
irocZ281986's Avatar
Car: 1986 Camaro Iroc-Z (sold)
Engine: 305 about to be 350
Transmission: full manual 700r4
Axle/Gears: auburn 3.42 limited slip
My irocz does it too. I have an 86 and no matter what gear it shifts in to it shifts at 6500 rpm every time. Sounds like I may need a tv cable adjustment too. I did find an article for it here too if interested.
https://www.thirdgen.org/detent
Old Aug 5, 2012 | 07:19 PM
jeff_blake's Avatar
i solved mine i think, it was a combo of things, its only for stop and go city driving, but 1st - 3rd is ok
g.l.mos
Aug 22, 2015 12:02 AM
crazynights
Aug 21, 2015 06:53 AM
dhonda200
Aug 11, 2015 11:50 PM
mustangman65_79
Aug 11, 2015 03:17 PM
