r700 to muncie 4 speed
Old Jul 18, 2012 | 03:16 PM
87irocftw's Avatar
Car: 1987 Camaro Iroc Z
Engine: 327
Transmission: Soon to be Muncie 22
So i am converting from auto to man in an 87 camaro. I bought nothing to special for a master cylinder just a sachs from rock auto. Now what i am wondering and looking for is, where the white plug is on the photo, i need to run a hose from there to a hyd. throwout bearing. from pictures it looks like a plastic hose. Can i use something different that has a slot for the little black bar in the photo? Sorry if this in unclear. I can provide more pictures to make it more clear.
Old Jul 20, 2012 | 01:17 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
Re: r700 to muncie 4 speed
Your title says r700 to muncie? A muncie does not have a hydraulic clutch. at least mine did not.
Old Jul 20, 2012 | 01:21 PM
87irocftw's Avatar
Engine: 327
Correct but they make swaps such as a hydraulic throw out bearing that mounts to trans and in a way makes it hydraulic. That is what I am looking to do.
Old Jul 20, 2012 | 02:06 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
this may help
https://www.thirdgen.org/forums/tran...83-84-4-a.html
Old Jul 20, 2012 | 02:14 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
and this, I considered the swap at one time as well.
https://www.thirdgen.org/forums/tran...uncie-4-a.html
Old Jul 20, 2012 | 02:22 PM
87irocftw's Avatar
Engine: 327
Yes I understand it's impossible a t5 or 56 would be awesome but I got the 4 spd in my possession and already have the pedal holes drilled. And idk lol try something different. No one else will have it
Old Jul 20, 2012 | 03:05 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
had one in a '67 and they are plenty tough, best thing about it was I could remove and install it without a jack! just pulled it onto my chest and wriggled out from under it. the car did ride a bit high though. 3000 rpm at 60 mph with 4.10 gears and topped out at just over 115 mph at 7000 rpm, but it sure got there quick!
Old Jul 21, 2012 | 12:39 AM
mastodon08's Avatar
Yeah man, I actually just decided on doing the same thing (putting in a Muncie 4 speed). They are tough transmissions no doubt. This older gentlemen I hang out with from time to time to talk cars has a '67 Camaro with a Muncie in there, and he was literally slamming it into gear when he took me for a ride; it took all the abuse just fine. He told me too that they have a kit for those transmissions to give them like an overdrive pretty much. They're expensive, but I think I'm going to put the 4 speed in and enjoy it until I have enough to get the kit for the overdrive.
Old Jul 22, 2012 | 03:55 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Love to see how it turns out! Keep us posted, pics would be awesome!
Elephantismo
Feb 13, 2019 12:51 AM
RedLeader289
Sep 23, 2015 06:50 AM
adelane
Sep 9, 2015 08:51 PM
Eric-86sc
Sep 7, 2015 02:10 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
