t56(?) id help
Old Aug 11, 2012 | 06:00 PM
Wolfskin's Avatar
Car: 87 Z28 and 90 Grand Prix STE
Engine: Z28-project 454, STE-turbo 3.1L
Transmission: Z28-4l80e, STE-4T65
Axle/Gears: Z28-truck 12 bolt posi 3.73
t56(?) id help
So today in the wrecking yard I found what I think is a t56 in a 97 camaro. But it's a v6 car. I tried to take some pics of it but they didn't come out well. All I see for numbers is cast into the driver side is 13-58-065-822 or 13-56-065-822. Hard to tell which. Any idea what this is? I'll try to post the pics. Thanks.
Old Aug 11, 2012 | 06:02 PM
Wolfskin's Avatar
Re: t56(?) id help
Ok, I have no idea how to post the pics of it.
Old Aug 11, 2012 | 06:39 PM
LilSki's Avatar
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
Re: t56(?) id help
Considering the T56 never came behind a V6 I doubt it is such. Most likely a variant of the T5.
Old Aug 11, 2012 | 06:49 PM
Wolfskin's Avatar
Re: t56(?) id help
That's what I first thought, but I'm real familiar with the t5 in the third gen cars and this looks nothing like it. Plus, the clutch slave is going into the bell instead of bolted to the outside. I really wish I could up load the pics of it. I'm hoping someone can recognize the numbers I listed. I've tried Google but couldn't find the numbers listed anywhere.
Old Aug 11, 2012 | 06:55 PM
LilSki's Avatar
Car: 85 Trans Am
Re: t56(?) id help
A quick search found you have the case # and really doesn't do much good. you really need the Tag # which is usually found on a blue tag towards the rear on one of the tail housing bolts.
Here is a pic of a T56 in my TA. Your saying the clutch slave setup looked like this?
Old Aug 11, 2012 | 07:08 PM
Wolfskin's Avatar
Re: t56(?) id help
Ok, wouldn't the case number tell me if it's a t56? I don't really care what it came from, just weather its a 5 or 6 speed. And no, the clutch slave was different. It had a braided steel line running into a brass cylinder, and it was at a 90 degree angle to the bell housing. Never seen anything like it before. And the starter provision was on the driver side instead of the passenger side. It was marked as a Borg Warner on the side of the tail above the cross member. Any other 5 speeds that were used than the t-5?
Old Aug 11, 2012 | 07:09 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: t56(?) id help
the t5 in the late 4.1 4th gen looks a lot different than a 3d gen t5, and the late ones had different TO bushing setups. Its not a t56
Old Aug 11, 2012 | 09:36 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: t56(?) id help
Originally Posted by Wolfskin
it's a v6 car.
13-52 is the Borg-Warner T-5 prefix on T5 parts. Either way, no T56 would have 13-5x on case parts.
That's an anodized aluminum cylinder; it's part of the concentric slave cylinder used in the mid-90s-up V6 F-bodies and 98-up V8 F-bodies.
One item definitely different than the third-gen T5 is the vertically taller bolt pattern trans. to bellhousing.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bigjay89gta
Oct 15, 2015 08:04 AM
meeklay812
Oct 1, 2015 03:46 PM
Vincent135
Sep 28, 2015 10:50 PM
