Where to find Speedo Gears
Car: 91 Camaro RS
Transmission: 700-R4
Axle/Gears: 373
Alright. I have done a rear swap. Changed from 373's to 323's. I have figured out that I need a green 42 tooth gear. I can't find anyone that carries it. Is there some place that I can get this thing quick? I am not liking my speedo being off by 10 mph, and since my lock up is supposed to be at 60, it isn't locking up till i hit 70 now.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Where to find Speedo Gears
Engine: Lb9
Transmission: M20
If you are wanting something in a hurry you can order this
http://www.summitracing.com/parts/DAK-SGI-5/
Car: 91 Camaro RS
Axle/Gears: 373
Ya, TCI doesn't have any, as they are discontinued. Checked with Summit, Jegs, and Dacco, all discontinued.
I went to the salvage yard and started pulling off the speedo sensor's on the 3rd gens, and they are all the wrong colors so far.
Axle/Gears: '01 3.42 10 bolt
http://www.transmissioncenter.net/sp...n_______va.htm
try here, i have used these guys before....good service. scroll down to see the gears
Car: 91 Camaro RS
Axle/Gears: 373
Wow, Thank you. But believe it or not, they are out of stock as well. The way things are going, once I get the right gear, I am going to buy one of each for possible future use. As if I change tire size in the future, I may not be able to get a gear for it. This is nuts that no one has this gear.
Are the gears in a 4th gen the same?
Car: 91 Camaro RS
Axle/Gears: 373
Well, I finally found one. One of the local Chevy dealers was able to locate one and order it for me. I just could not believe that everyone is selling out of this one. This dealer stated that the place they found it only has 1 more left after my order. Then they will not be carrying it anymore as well. Kinda makes me want to go and buy one of each color so if I ever change tire size, I have one that will work.
Engine: Lb9
Transmission: M20
ambainb
Apr 25, 2016 09:21 PM
beachrodder
Aug 7, 2015 04:27 PM
