305tpi with 3:73 0-60
Car: 91' Z28. 70' Dune Buggy
Engine: LSX Cam/Full Bolt ons
Axle/Gears: 4.10
I haven't been to the track, so I can't truly relate to 60' and 1/4 mile times, however I can relate to 0-60mph times.
I have a ram air/catback 305tpi 700r4 with a stock limited slip 2:73 with 275 tires out back.
What will my 0-60 time be if I swapped to 3:73 gears. Will there be a night and day difference?
I've searched with not much luck, atleast for 305tpi with 700r4's
Car: 1986 Chevrolet Camaro
Engine: 355 chevy
Transmission: t-5
Axle/Gears: 3.73 disc brakes
Re: 305tpi with 3:73 0-60
i went from 3.23 and was night and day difference, but i was one wheel peel to 2 wheel posi also
Axle/Gears: 4.10
Did you go from 3:23 to 3:73, or 2:73 to 3:23?
Anyone else have input? Even with 3:70 gears?
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
3.73 is way too short for a TPI. You'd be best off with 3.42s.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Axle/Gears: 4.10
Car: 1988 Formula Firebird
Engine: 5.3 LM4
Transmission: 4L65E
Axle/Gears: 3.42 True-Trac
My TBI car started out life with a 2:73 rear. I swapped the whole diff for a 3:73 unit. Didn't notice any signifacant loss in mileage but the fun factor went up big time. Tall gears anywhere but the highway are just boring. I actually have 3.42s now, and its a happy medium. My 3.73 rearend blew up.
Car: 91 z28
Transmission: 5 speed
well i would like to know what are the gears of a stock 1991 Z28 305tpi 5 speed manual... and what would happened if i upgrade to 3:73 gears?
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
When I had my 305 tpi, I went from a 2.73 to a 3.42.
I had some mods by then so the difference was night and day in low end torque.
I lost a bit in fuel mileage.
I had a hard time spinning the tires with the 2.73's, and then it was no problem with the 3.42's.
Car: 91 z28
But doenst camaros have already 3:42s from factory? Because i was trying to find some information on this website about the gears they came out from factory, but the only gears that appeared are the 3:42s for the 305tpi 5speed manual so im confused... Was your manual?
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
There are various gear ratios and even rear ends that were used in Third gens. Before picking you gears I would start by at least finding out if its a 9 bolt, 10 bolt, or Dana 44. At that point you know the ring size needed, but series of the carrier inside will depend on what gears you get too.
Posted from Thirdgen.org App for Android
