Speedometer Drive Gear
Old Mar 30, 2013 | 10:12 AM
robmaxfli's Avatar
My T5 has a RED drive gear but it only has 7 teeth on it (not 9). Everything I've read on here says that the RED gear has 9 teeth.
Am I missing something here?
Old Mar 30, 2013 | 01:11 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Speedometer Drive Gear
Yes. Going by color is silly.
Post pictures and measurements; it could be another application gear that worked.
Old Mar 30, 2013 | 02:53 PM
robmaxfli's Avatar
Ok - here is a pic :
Old Apr 5, 2013 | 01:50 AM
jmd's Avatar
jmd
If the o.d. is about 1.84", then it's more than likely one of the recent reproduction gears. If smaller, it's another application.
Old Sep 7, 2013 | 11:43 AM
robmaxfli's Avatar
My speedo is still off (too fast) even though I did the calculations correctly ( I thought).
Dumb question: How many teeth are on my drive gear shown in the pic above ? 7 or 8?
Old Sep 7, 2013 | 11:59 AM
jmd's Avatar
jmd
Go pop out the VSS or driven gear, hit it with a sharpie and use a mirror (or lower the crossmember) and:
Old Sep 7, 2013 | 12:21 PM
robmaxfli's Avatar
The one in the pic above is the actual one that I have. It seems as if you can count 7 0r 8 depending on if you include the smaller ones on the sides.
How many would you say I have?
Old Sep 7, 2013 | 01:50 PM
Look at the END of it.
Count the teeth as they come to the end.
Not that hard.
Looks like a 9-tooth (2 series) to me.
Old Sep 7, 2013 | 03:40 PM
gt4373's Avatar
Transmission: 5-Speed Manual
Count The Teeth From This Side.
Old Sep 7, 2013 | 04:45 PM
jmd's Avatar
jmd
7 or 8. Maybe 9.
jmd's Avatar
jmd
Could be 10.
Old Sep 7, 2013 | 04:46 PM
jmd's Avatar
jmd
what I (and sofa perhaps too) would like to know:
How did it have 7 in March?
Old Sep 7, 2013 | 06:59 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Looks like a 7 to me,....
I've got gear charts from 82-87 and they all show a 7-tooth red for MK6 and M39.
Old Sep 7, 2013 | 10:56 PM
jmd's Avatar
jmd
I've changed a few 9s to 7s. What years were they? Well, some were definitely from 88 to 92.
What tooth count does rob have? We may never know!
Old Sep 8, 2013 | 09:00 AM
robmaxfli's Avatar
It is a WC T-5 - I don't know from what year though.
I can't look at it from the side anymore because the trans is installed now.
I am taking other opinions on how many teeth are there.
Old Sep 8, 2013 | 10:02 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
The GM T5 drive gears come in 7 (Blue) and 9 (Red) only. You count the thread starts (or points) on the side to determine tooth count. It's called a "multi start thread".
I have both gears in stock and just took this pic with both a 7 and a 9 side by side. You can easily see the difference.
Old Sep 9, 2013 | 12:00 PM
robmaxfli's Avatar
Ok - much appreciated
Old Sep 9, 2013 | 12:11 PM
I have NEVER IN ALL MY DAYS seen a 7-tooth red gear.
Every 7-tooth one, WITHOUT EXCEPTION, that I have ever seen, has been blue. I have personally thrown several 9-tooth red ones in the trash that came to me in T-5 cores, because I have less than zero use for such ... trash. I don't need it cluttering my space and getting in the way of stuff I actually DO have a use for.
Wouldn't be the first time something that GM (or any other mfr for that matter) has published has been incomplete or just plain WRONG. Probably won't be the last.
The experience of LOOKING AT PARTS sometimes has to be believed over what's printed, even in the FSM.
Since the gear in the pic shows 4 complete teeth in the part that can be seen, which is somewhat less than half of the gear, it is entirely reasonable to conclude that it has somewhat more than twice as many as 4 teeth. 9 is COMPLETELY consistent with this logic. 7 is not.
If your gear is red, it's a 9-tooth.
Frozer!!!
Jan 19, 2024 04:55 PM
jklein337
Sep 19, 2018 06:23 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
jharrison5
Aug 19, 2015 05:53 PM
