700r4 question
700r4 question
I'm doing a basically stock rebuild on a 90 (i think) transmission. the check ball capsule at the very end of case near tail housing. the ball fell out and capsule is damaged. do I need this and where can I get one if i do.
Re: 700r4 question
I can't get one up. it's the at the rear of the valve body in the case. I've heard some one say to leave it out but don't remember exactly what the reason was. maybe a shift kit. just wandering if i can leave it out or where I can get one. not having luck finding one.
Car: 1989 IROC-Z28 Camaro
Engine: none
Transmission: T-56 W/ Spec 1 Clutch
Axle/Gears: 9 Bolt BW 3.27 Gears
Re: 700r4 question
if your leaving it completely stock without a shift kit then i would say to find where it goes and put it back
Re: 700r4 question
If this is the one that sits in the rear of the case just over the low/reverse piston apply feed holes, then leave it out. Makes for a better reverse apply. ATSG book has you remove it also.
Iroc8t8
May 4, 2026 08:09 PM
[/IMG]
