89 IROC-Z Vert- 700R4-T56 SWAP!
Old May 6, 2013 | 11:09 PM
KMdoza7's Avatar
Car: 1989 IROC-Z28 Camaro
Engine: none
Transmission: T-56 W/ Spec 1 Clutch
Axle/Gears: 9 Bolt BW 3.27 Gears
Well its finally time to start my T-56 swap into my IROC.
I hope you guys can help me out with any questions that i might have throughout the processes and i hope that it can help someone else that might be interested in doing the swap.
so far i have 1700 into the swap
Im using:
Spec steel flywheel and spec 1 clutch: new bought for $520, LT1 Bellhousing, & clutch fork $140 from TGO member Warnd
3rd gen pedals W/ all switches and pigtails: $75 ( 4th gen clutch pedal $20)
4th gen clutch hydraulics: $105 new from Amazon
3rd gen shifter plate: $75
Custom Crossmember: $70
T-56 trans W/ Stage 2 rebuild, wiring harness, mounts, clutch fork, shift boot, & shifter (from a 95 TA): $600
Here's some pics of my IROC:
Old May 6, 2013 | 11:18 PM
KMdoza7's Avatar
Engine: none
Re: 89 IROC-Z Vert- 700R4-T56 SWAP!
Here's pic of my parts:
pedals, shifter plate, hydraulics, custom Xmember, (transmission is not in yet)
Spec steel flywheel & spec 1 clutch
SPEC
Old May 6, 2013 | 11:34 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/forums/tran...swap-made.html
If you end up with any bucking on decel you will need to have your memcal reprogramed . bullydog made a great write up on the swap.
Old May 7, 2013 | 01:08 AM
KMdoza7's Avatar
Engine: none
Im planning to get NINETYONE to burn me a custom chip for my car.
Old May 7, 2013 | 01:58 AM
Engine: Lb9
Transmission: M20
Old May 7, 2013 | 02:18 AM
KMdoza7's Avatar
Engine: none
why are you confused?
now im confused. did i say something dumb? lol
Old May 7, 2013 | 02:22 AM
Engine: Lb9
Transmission: M20
I didnt realize he had any ads for reprograming is all,, The idle air control logic and spark tables are different from automatic to manual. You should drive it and decide if if you have a issue.
Btw I'm jelious of your t56
Last edited by Tuned Performance; May 7, 2013 at 02:37 AM. Reason: More information
Old May 7, 2013 | 05:23 AM
KMdoza7's Avatar
Engine: none
Ninetyone messaged me and offered to burn me a chip for $50. so i mean idk lol. ill look more into it though.
and btw 89 camaros came with mechanical speedos right? just making sure
Old May 7, 2013 | 09:23 AM
Engine: Lb9
Transmission: M20
Yes the 89 has a cable drive speedometer.
https://www.thirdgen.org/forums/engi...ble-drive.html
Old May 7, 2013 | 10:33 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
He said he would burn me a custom prom for $50. so i mean idk lol. ill look more into it though...
Get a chip burned by a sponsor, Brian (Tuned Performance) has been burning chips for a very long time and he knows what he is doing, and stands by his work. Ninetyone seems to bad mouth 3rd gens on a regular basis from what I can see and hear, and he doesn't even own one anymore, so take what he says at face value when it comes to burning proms for these vehicles...
Old May 7, 2013 | 11:07 AM
KMdoza7's Avatar
Engine: none
ok will do thanks.
iv been looking on many threads about using 3rd gen pedals w/ 4th gen hydraulics. i was wondering for you t-56 guys out there what setup has worked best for you guys?
Old Jun 26, 2013 | 11:31 PM
KMdoza7's Avatar
Engine: none
ok...well i finally got my T56. i got it for 600 W/ a stage 2 rebuild and less than 3k miles on it. i have collected all the parts i need for the swap, today i mounted my pedals and my clutch hydraulics. i used the 3rd gen bracket w/ 4th gen clutch pedal, so hopefully i wont have any problems with my clutch engagement now ., installed my clutch,cut my shifter hole ( turn out pretty nice!), and wired my reverse lights for the trans, so now i need to send my t56 tailhousing to ALLOY for a cable speedo conversion, and either have someone make me a chip or learn to do it myself. i will post some pics of my progress tomorrow
Old Jul 12, 2013 | 02:50 PM
KMdoza7's Avatar
Engine: none
Well before i get my tailhousing converted to a mechanical speedo, i would like to get some rearend gear ratio suggestions PLEASE.
I have the BW 9 bolt W/ 3.27 gears
I can either put the motive 3.70 gears in the 9 Bolt or i can swap the rear for a 4th gen rear W/ 3.73 gears from my local junkyard for $500. or is there any better options?
Old May 18, 2014 | 01:19 PM
hartsmike's Avatar
Car: 1986 Black IROC
Engine: 305 Quadrajet
Transmission: 5 speed
Axle/Gears: 273
Updates?
Old May 24, 2014 | 02:21 PM
KMdoza7's Avatar
Engine: none
I finished the swap awhile back, the thread wasn't getting many response so I decided to stop updating.
Old Jan 5, 2015 | 04:50 AM
Engine: Lb9
Transmission: M20
Hello Kevin, Can I please get you to return the memcal I loaned you ?
CamaroGuy350
Aug 30, 2015 02:56 PM
CamaroGuy350
Aug 26, 2015 05:11 PM
StevenB L98/LS1
Aug 22, 2015 09:03 AM
g.l.mos
Aug 22, 2015 12:02 AM
