How many T5 owners removed or have no counter weight
Old Jul 12, 2013 | 09:37 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
How many T5 owners removed or have no counter weight with no issues.
it does weigh a ton, suspose to help absorb the effect of the rise and fall of the tranny. Mine is tight but still kinda jiggles in its mount, I could remove it, or investigate why its wiggling some and stop it...........
Old Jul 12, 2013 | 10:04 AM
Re: How many T5 owners removed or have no counter weight
No V8 cars came with that at all.
It's strictly a 6-cyl thing.
Has nothing to do with "rise and fall".
Can't see how getting rid of it would cause any problems, other than maybe you'd get a little more vibration.
Old Jul 12, 2013 | 11:56 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
I dont use one on my v6. No issues at all
Old Jul 12, 2013 | 01:21 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Well, now, this discussion has amused me no end. Why? In all the years I've been a member here, I've never heard mention of the piece in question. A quick Google brought me up to speed. I'm livin' and learnin'!
Some V6 and V8 cars were equipped with a secondary cross member which was supposed to help with vibration. But again, the piece above is new to me.
JamesC
Old Jul 12, 2013 | 05:06 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Well mine moves up a good 3/4 of a inch, so each time I hit a bump that jumps up then comes down, thinking its causing more road vibes then it would help right now.
Old Jul 12, 2013 | 08:39 PM
Throw it in the trash.
Old Jul 17, 2013 | 09:17 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
JamesC
First time I saw one about 10 years ago I was wondering what the heck it was too. I think most of 'em got discarded with the first clutch job.
-- Joe
Old Jul 17, 2013 | 09:23 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I put a big plastic zip tie around it for a test to hold it up / take the wiggle/slack out of it. It was noticable in the stick on my nasty roads.
But back into the 90s and just being out side is to much work, gonna hafta wait a bit.
Old Jul 18, 2013 | 10:48 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
The NVH guys at GM put that there. It changes the resonate frequency of vibrations coming from the trans. You probably wont notice any problems without it. GM engineers use vibration detecting equipment and I guess the vibrations coming from that area was over the acceptable range so they put a weight on it to lessen it. Working at a ford dealership, I see weights on all kinds of parts on cars. Exhaust is usually the ones that have it but I've seen them on trans and suspension parts also.
Old Mar 9, 2014 | 05:19 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Ended up keeping mine, once I got the slack out of it so it didn't jiggle when I fixed the torque arm mount.
https://www.thirdgen.org/forums/tran...e-t5-load.html
Did give a spare to a buddy to use on his ford truck long ago, and it helpped him. but his was a rise and fall problem. [why i asked] from massive torque, as he put two 4 speed stick trannys end to end, giving him a mega range. Was fun to shift gears going backwards.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Aug 23, 2015 03:49 PM
theurge
Aug 21, 2015 12:46 PM
3rdgenparts
Aug 8, 2015 07:09 PM
