VSS "bullet" and driven gears not removable in '86 Firebird with T5?
Old Jul 28, 2013 | 01:31 AM
Corellian Vette's Avatar
Car: 1986 Firebird
I recently went from 2.73 to 3.42 gears in my 86 Firebird
Found out (afterward) that the original metal shaft/plastic gears are not available, but could be swapped over using TH350 bullet and plastic gears.
Well - I pulled the VSS off my 86 Today, and it looks like my assembly is all one unit - the bullet and the sensor don't look like the come apart. In fact, I can't see any way to disassemble it at all.
Anyone know if this is normal? Am I just missing something?
I need to get those gears changed because my speedo is way off!
Thanks!
Old Jul 28, 2013 | 01:43 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: VSS "bullet" and driven gears not removable in '86 Firebird with T5?
https://www.thirdgen.org/forums/prof...do=editprofile
That's where you add what your vehicle is.
I'd have not provided info I did in you prior thread if you had 86 F-bird indicated.
Old Jul 28, 2013 | 01:46 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by Corellian Vette
I pulled the VSS off , and it looks like my assembly is all one unit
You are talking about a VSS that has a plug on it .........not a cable drive unit ?
A VSS is completely different to a speedo drive ( TH350 style ) that uses the bullet and gears with a shaft on them .
On a VSS you just slide the gear off the shaft and replace it; no dis-assembly required
If you are swapping to a cable speedo then you use nothing from the VSS
Old Jul 28, 2013 | 01:54 AM
Car: 1986 Firebird
Correct. My car has a VSS not cable drive. My setup doesn't look exactly like that, but similar.
I'll fill that out.
I don't see how that gear comes off... mine slides up and down, but doesn't appear to actually come off?
So now what do I do? Where do I get a 20 tooth gear for this unit?
Old Jul 28, 2013 | 02:07 AM
Car: 1986 Firebird
Correction looks like I need the 19 tooth white gear...
Old Jul 28, 2013 | 02:19 AM
jmd's Avatar
jmd
what tire size?
Old Jul 28, 2013 | 02:21 AM
Car: 1986 Firebird
normal 26 inch (225 60 15)
Old Jul 28, 2013 | 08:48 AM
jmd's Avatar
jmd
If they're he same height as a 215/65R15 you're fine with a 20.
If they're more like the height of a 195/75R14 or 205/70R14, go with a 19.
Might have a 19 w/ steel shaft (remove it to use on a VSS) if you're looking for one.
The inner diameter of the gear has a ridge that holds it on the VSS and the flat side to prevent spin.
Old Jul 28, 2013 | 09:18 AM
joshc's Avatar
Car: 1986 Trans Am
my 86 with 700r4, the stock plastic gear just slides of the sensor shaft.
I bought my gears off ebay as they were discontinued from gm.
Old Jul 28, 2013 | 11:44 PM
Car: 1986 Firebird
If you do, I'd be happy to pay you for it! That will get me much closer!
Old Jul 29, 2013 | 02:10 AM
jmd's Avatar
jmd
Didn't find the 19, only a 21 and 22.
1992rs/ss
Jan 31, 2025 05:10 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
mizz0313
Aug 12, 2015 06:45 AM
3rdgenparts
Aug 8, 2015 07:09 PM
