700r4 problems
Car: 89 Formula WS6
Engine: LQ4 h/c/i
Transmission: TH-FO-HUNNIT
700r4 problems
I have a Monster rebuilt 700r4 transmission, and it worked great to begin with.. but now only first gear and reverse work. Does anyone know what the problem could be? Monster told me it is most likely the valve body, and they will pay for parts, but not labor. I am a good mechanic and can do a lot of things myself, so I can replace it whatever has to be done. If I replace the valve body if that is what is it, then is it an easy fix? And does anyone have a DIY as to how to do it? It would really help because I can't drive my car!
Car: check
Engine: check
Transmission: check
Re: 700r4 problems
Having just first and reverse is a sign that the governor gear has gone away. Under the domed cover, drivers side, toward rear of transmission.
RBob.
RBob.
Car: 89 Formula WS6
Engine: LQ4 h/c/i
Re: 700r4 problems
Do you have to pull the transmission out of the car to replace that?
Car: 89 Formula WS6
Engine: LQ4 h/c/i
Re: 700r4 problems
And are you sure that is the problem? I'm not sure how much monster would replace. Thu might think I'm just trying to get parts, so I don't want to replace many things on it, if you get what I'm saying?
Car: check
Engine: check
Transmission: check
Re: 700r4 problems
Otherwise, let Monster Transmission honor their warranty. But then again, maybe the trans is out of warranty, but maybe not. I don't know.
I also don't know if the g-gear is gone, as I can't see it from here.
15 - 30 minutes and it's out, take a look at it...
RBob.
Car: 89 Formula WS6
Engine: LQ4 h/c/i
Re: 700r4 problems
Well, I replaced the governor gear.. and about 260 miles later, it stopped shifting again... and I thought it was due to the shift boot being too taught.. but I just took it off and the transmission won't let me pull down into first.. Like, the transmission will literally not go down into first by the shifter.. it stops at 2nd gear on the shifter.. Do you know what this could be caused by? Sorry that I've been asking so many questions..
Car: 89 Formula WS6
Engine: LQ4 h/c/i
Re: 700r4 problems
It stopped shifting again and I can't manually shift through because the shift boot is too taught. Sorry, should have been more clear.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 700r4 problems
If you can , then the shifter/ cable is your problem.
If you can't ,then the problem is inside the trans
someone972
Aug 30, 2015 12:52 AM
