327 engine and tranny swap
Old Aug 20, 2013 | 07:10 PM
tlawrence's Avatar
Car: 1987 Camaro Z28
Engine: 5.7 Liter 327
Transmission: A4
I just bought a 1987 Camaro Z28 from a friend. The stock engine has been replaced with 327 small block but the tranny is still standard. I was wondering if it is possible to swap the stock automatic tranny for a manual T-56. If i do, would I have to worry about the engine mileage vs. the transmission's mileage. Would the two mate properly? What safety or mechanical issues might I come across? I've worked on cars before but this will be the biggest thing I've done and would like to do it safely and correctly. Im also planning to upgrade to a 427 sometime in the not to distant future.
Old Aug 20, 2013 | 07:22 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: 327 engine and tranny swap
A 327 is for all intents and purposes, a 1985 and older 350.
https://www.thirdgen.org/forums/tran...ap-thread.html
Of what you've asked, it's covered in that thread.
Old Sep 19, 2013 | 08:07 PM
tlawrence's Avatar
Transmission: A4
An issue that I forgot to mention was that the 305 engine was swapped for a 327 from a 79 corvette. Also I guess whoever did that couldn't find a way to properly mate the bell housing so they simply left it off. MAJOR SAFETY ISSUE! How would I find a replacement bell housing to resolve this short-term and if I decided to use a short-block 454?
Old Sep 19, 2013 | 10:32 PM
T/Aperformance's Avatar
Car: 1987 Trans Am
Engine: 355 tpi
Transmission: 5 speed
Well First I wounder really what year the 327 is, It may have came out of a 79 corvette but that engine was never a factory option that year, They stopped making that engine years before that.
When you say bell housing what do you mean, with out the bell housing the transmission will not can not be connected to the engine, If you have an automatic transmission right now the bell housing is part of the trans, If you are talking about a manual trans any bell housing for a gen 1 sbc will work on you engine. Even the LT1 bell housing is the same,The flywheel is different and you would need one from a gen1 sbc that has the two piece rear main seal.
camaro11j
Sep 19, 2018 08:49 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
hokis
Aug 9, 2015 03:57 PM
