Installed POSI...Car feels slower..why?
Old Aug 23, 2013 | 10:38 PM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
Hey guys so just yesterday I installed a POSI rear end off a 4th gen...the gear ratio on it is 3.23...but now that its on there...I feel as if the car got slower...is it just more strain on my engine that it struggles to move both of the wheels....PS i have an LG4 engine w/ mods. So Im guessing that might be the culprit right there.
Old Aug 23, 2013 | 10:56 PM
big gear head's Avatar
Re: Installed POSI...Car feels slower..why?
What was in it before you swapped the rear end?
Old Aug 23, 2013 | 10:57 PM
calgutie's Avatar
Car: 1984 Z28
It was open differential with what I believe had 3.23 gears. Its kinda funny because b4 the car could easily burnout with the open differential rear end..and now it struggles to burnout both tires...
Old Aug 23, 2013 | 10:58 PM
calgutie's Avatar
Car: 1984 Z28
the rear end came off a 2001 WS6 automatic
Old Aug 23, 2013 | 11:21 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
it is trying to turn both tires- of course it's going to have to work harder to do it. that's the whole point of a positraction differential.. but burnouts are wasted energy, anyways- now that energy is being used to move the car instead of laying a single black streak on the pavement ...
Old Aug 23, 2013 | 11:49 PM
Yea, you have more than doubled the traction, so it's not going to spin the tires as easy. I hope you put new tires on the rear when you swapped the rear end. If the tires don't have the same amount of tread then it will cause the differential to slip all the time while you are driving it and it can damage the differential. The air pressure also must be kept equal between the rear tires.
Old Aug 24, 2013 | 12:41 AM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
you went from burning out one tire to burning out both. twice the work for the engine.
Old Aug 24, 2013 | 07:20 AM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Trying to sell E-lockers?
Old Aug 24, 2013 | 03:01 PM
Old Aug 24, 2013 | 07:41 PM
calgutie's Avatar
Car: 1984 Z28
ye so now I need to beedf up my engine more so that it can spin those two tires...or like everyone else says "drop a 350" Now my other problems is that my tires rub on my fendors.
Old Aug 24, 2013 | 11:07 PM
novaderrik's Avatar
Car: 86 Camaro
either roll the fenders or get wheels with more backspacing.
Old Sep 1, 2013 | 10:06 PM
calgutie's Avatar
Car: 1984 Z28
alright guys this might sounds kinda dum....but how exactly do I do a burnout now since all of my 4 tires are braking now..I find it hard to get my rear tires to break loose if im holding the brakes...aka I have a manual transmission.
Old Sep 1, 2013 | 10:17 PM
If you have a manual transmission why are you holding the brake? Just rev it up and dump the clutch!
Old Sep 1, 2013 | 10:18 PM
calgutie's Avatar
Car: 1984 Z28
ye i know that but i want to hold still while im burning out..aka to show off...LOL
Old Sep 1, 2013 | 10:21 PM
Hurst Roll Control.
Old Sep 1, 2013 | 11:51 PM
885speed's Avatar
Car: 1988 Camaro
Engine: LR4
Axle/Gears: 3.23posi/disc
I just finished my swap today 3.08 open/drum>3.73 posi(auburn)/disc and left two very nice black lines on the test drive.(very tired stock L03)
How are you attempting to brake stand it(burnout)? I'm guessing your using the side-step method?
Old Sep 2, 2013 | 08:28 PM
calgutie's Avatar
Car: 1984 Z28
yes thats the moethod im attempting to use unless you got something more effective?
Old Sep 2, 2013 | 09:11 PM
plum92_camaro's Avatar
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
My 92 is a LO3, t5, 3:42 posi,drum and burnouts have never been a problem (except with drag radials, those were some hard launches). Tires are 255/50r16. Rev it up and dump or slip the clutch. if you want to do brake stands, try reving it up, dump the clutch then move to the brake. It's worked for me.
Back in the day it was always fun blowing away all the 3:08 open rear cars, and being able to take some 5.0's down with a LO3.
Old May 13, 2014 | 11:31 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
That's what line locks are for, install line locks, flip a switch that locks only the front brakes and drop the clutch :P
Old May 14, 2014 | 01:36 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
LG4
Could have had 3.73 rear gears in 84 if I'm not mistaken.
Frozer!!!
Jan 19, 2024 04:55 PM
I'llrocya
Feb 2, 2016 11:43 PM
fasteddi
Sep 2, 2015 10:29 AM
dhonda200
Aug 11, 2015 11:50 PM
flash2042
Exterior Parts Wanted
Aug 7, 2015 05:58 PM
