Bellhousing Question
Hey guys,
I put a tremec 5 speed in my 85 IROC. Unlike the stock transmission, this transmission sits level in the car. Does anybody know what kind of bellhousing I can use that will keep my stock fork and slave cylinder but will change the bolt pattern for the transmission from the angle pattern to the level pattern? I was thinking something like a c4 corvette bellhousing but I think they may have different slave cylinder mounting brackets...
Thanks!
Thanks!
Car: `86 SS / `87 SS
Re: Bellhousing Question
They do have different brackets so it would be a try & see how it goes.
A Lakewood 15020 is dual-pattern and would work.
Other ideas here in the bellhousing page: http://www.garage-scene.com/t5-into-ag-body/
Wouldn't be too hard to fab up a bracket that would bolt to the trans bolts or the like.
Although the ballstud location for the fork pivot is different in the 84-92 F bellhousing than it is for the 84-88 Vette so bolting the F slave up isn't an immediate solution. Master to slave volume ratio needs changed.
Fabricating one wouldnt be hard but its magnesium and a 50 dollar bellhousing from a junk would be much easier.
Anyone know of ANY bellhousing that will work for this application?
Thanks!
but its magnesium
I am going to need to use the corvette fork or will my stock fork fit correctly?
Ballstud location change means the fork is different.
Are you saying the 84-88 vette bell is mag? Didn't know that.
I think im gunna try to pick up a bellhousing for cheap and see if I can modify a bracket to work with my stock slave...
Thanks!
BlackphantomZ28
Apr 24, 2016 08:14 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
383backinblack
Aug 15, 2015 06:36 PM
