Best Gear Ratio for a Daily Driver
Old May 12, 2014 | 09:08 AM
MustangBeater20's Avatar
Car: 1991 Camaro RS
Engine: Built TBI 350
Axle/Gears: 3.42 Posi
I'm building a vortec 350 with around 380hp. I'm replacing the rear end soon. What gear ratio should I go with? This is my daily driver and it's a 5 speed. It currently has the stock non posi 3.08 gear in it now.
Old May 12, 2014 | 10:14 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Re: Best Gear Ratio for a Daily Driver
I hear a lot really enjoy their 3.42's. If you'd like even more bite that shouldn't cause problems being a daily driver, go with 3.73's.
Old May 12, 2014 | 10:16 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
I think best all round is 3:23 / 3:27. With that power plenty of acceleration and lower high speed rpm.
Old May 12, 2014 | 10:41 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
With my 350/330 and T-5, I like 3.23's, which seem well suited for both town and highway driving.
JamesC
Old May 12, 2014 | 11:20 AM
RamIt's Avatar
Car: 1984 z28
Engine: Crate replacement L31R 350
Axle/Gears: 7.625" 28 spline 3.23
3.23 if you have the .73 fifth gear. 3.73 if you have the .63 fifth gear. Both setups spin the same rpm in 5th on the highway.
Old May 12, 2014 | 12:22 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Agreed and I have run both combos. 3.73 with a .73 gives lots of acceleration on the expressway but MPG suffers bad
Old May 12, 2014 | 01:14 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
It really depends on what kind of driving you do more of - highway or city. My camaro had 3.42s in it stock, and they were nice as an all-around gear, but I really like the 3.73 i swapped in a couple years ago. I don't do much highway driving in my camaro though, so highway mileage isn't as important to me. If it was, i would have kept the 3.42s.
Old May 12, 2014 | 03:18 PM
AutoRoc's Avatar
Engine: Vortec 4200 Inline 6 PT70 Turbo..
Transmission: 4L65E
3.73 puts you at 2500rpm at 75mph. Works for me. You can trap 120-125mph at the top of your 1:1 ratio around 6500rpm.
Old May 12, 2014 | 05:53 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Either of these would be a good compromise. My son's GTA has the .73 fifth with a 3.45 axle. Performance on the highway is excellent (no downshifting required), but the motor spins just a little too fast, feels like it needs a sixth gear.
LittleFranks
Sep 17, 2015 12:22 PM
hectre13
Aug 26, 2015 08:17 AM
ChaseDale3and8
Mid-West Region
Aug 25, 2015 06:34 PM
InfinityShade
Aug 22, 2015 08:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
