Transmission still engaged even in neutral, help please
Old Nov 21, 2014 | 10:46 PM
zachariahZ28's Avatar
Car: 1984 camaro Z28 H.O
Engine: 5.0 H.O
Hey guys I had taken my transmission off and tried to be build it my self, after the first time I was unable to get it, then I took it off again and took it to a transmission shop. Anyways I ended up picking it up when I threw it back on the drive shaft won't move freely and when I start it it wants to move is there any hint on why this is happening, I know I'm gonna have to take it off a third time, I'm just wondering if anybody has any input on the subject? Any advice would be much appreciated, I'm missing my car
Old Nov 22, 2014 | 12:28 PM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
Did you get the shift cable adjusted correct? It may be engaged in reverse. I believe the farther the lock nut is towards the motor would move it back
Old Nov 22, 2014 | 03:44 PM
Engine: 5.0 H.O
Re: Transmission still engaged even in neutral, help please
It's a t5, which I'm guessing doesn't have it? Correct?
Old Nov 22, 2014 | 04:29 PM
Car: 91 formula ws6
Transmission: 4l60E
Lol. Sorry I'm on the mobile app so I didn't see what you have. Take the shifter off and make sure its centered when you drop it in. It make be off a bit
Old Nov 22, 2014 | 04:35 PM
Engine: 5.0 H.O
Okay got you, could the shift forks be put in in gear when it was set in? Just a thought, caus is there a specific way to put that on? But I'll have to check that tomorrow, cause unfortunately it's raining here -.-
Old Nov 22, 2014 | 04:41 PM
Car: 91 formula ws6
Transmission: 4l60E
Its 27* here so I feel that. I read they are similar to the super ten truck transmissions in shifter function, I'd imagine that the shifter end fits into a cup in the rod. You'll see what I'm talking about when the shifter is unbolted. Can you hear the shift forks moving when you try to engage a gear? Or does it not go thru all the gears when trying to shift it around?
Old Nov 22, 2014 | 04:43 PM
Car: 91 formula ws6
Transmission: 4l60E
https://www.google.com/search?q=t5+s...AYQ_AUoAQ#i=18.
It is similar to what I work on daily.
Old Nov 22, 2014 | 05:07 PM
Engine: 5.0 H.O
Yes sir that's exactly it, and Yes it does fit into a cup that I do remember, but no it didn't go through all the gears
When it was up in the air the tires started moving, so I was tried to put it into some gear to stop it or see what happens and nothing, at most it grinded then I stepped on the brake and it stalled out. I turned it on a again and pressed in the clutch then held the brake and the tires stopped
Old Nov 22, 2014 | 05:17 PM
Car: 91 formula ws6
Transmission: 4l60E
Def engaged. Try that first, if not you may have to pull it and find out what happened.
Old Nov 22, 2014 | 05:22 PM
Engine: 5.0 H.O
Okay, if I redo the shifter and that's not it and I take it off what should I be looking for? When the shift assembly was off I could move both gears into gear no problem, and suggestions?
Old Nov 22, 2014 | 07:04 PM
Car: 91 formula ws6
Transmission: 4l60E
Sadly past that I'm no help. That's the only thing I know about these transmissions. The shifter not sitting in the cup is familiar to me.
Old Nov 23, 2014 | 03:42 PM
Engine: 5.0 H.O
Okay can you give me any input on this, I took it back off and mocked up the shifter and slid the driveshaft in and it worked just fine, but once I try to set it back in to the bell housing the drive shaft stays stuck as if it's in gear? But yet I check on top and it in neutral and if I slid the tranny back out it moves freely lol any thought?
Old Nov 23, 2014 | 05:26 PM
HankL69's Avatar
Car: 85 IROC / 69 Firebird convertible
Engine: 5.0 / 350
Transmission: t-5 / WC t-5
Axle/Gears: 3.27 / 3.08
When you say that it moves freely when it is out are you saying that the input shaft and output shaft can move independently , or that you can spin the shaft easily. When the shifter is in neutral you should be able to turn the input without the output moving. If that doesn't happen something internally is locked up.
Old Nov 23, 2014 | 05:35 PM
Engine: 5.0 H.O
When I turn the input shaft the output turns as well, so that means it's internal?
Cause I'm holding the input and trying to turn the output and it won't move
Old Nov 23, 2014 | 06:26 PM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
That means your transmission is "in gear" and not in neutral.
Turn the input shaft...
Does the output shaft turn the same way? = Forward gear. Or the opposite direction? = reverse.
Turn the input shaft so the output shaft turns 1 full rotation.
How many full rotations of the input shaft did it take? 3, 2 1/4, 1 1/2, 1, 3/4? That will tell you which gear is selected.
Old Nov 23, 2014 | 10:12 PM
Engine: 5.0 H.O
Okay so I found out the shift actuator broke it was set in5th gear, now hopefully I can find one tomorrow by some divine miracle
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
sahlomonic
Sep 20, 2015 07:15 PM
InfinityShade
Sep 18, 2015 08:32 PM
Stroopwafel
Sep 11, 2015 06:38 AM
Glowsock
Sep 6, 2015 06:40 AM
