10 bolt
Old Mar 11, 2016 | 10:16 PM
Iroc_Lopez28's Avatar
Car: 1988 IrocZ
10 bolt
Not sure if this is the right thread for this but my buddy was just curious if there was anything special about this rear end? Thanks for the help!
Attached Thumbnails 10 bolt-fb_img_1457755457661.jpg   10 bolt-fb_img_1457755462089.jpg
Old Mar 12, 2016 | 06:58 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 10 bolt
If the PBR calipers are original to the rear, it's from a 90-92 car.
JamesC
Old Mar 12, 2016 | 10:00 AM
Car: 1988 IrocZ
Re: 10 bolt
JamesC
So it's just a 10 bolt with upgraded brakes?
Old Mar 12, 2016 | 11:18 AM
JamesC's Avatar
Re: 10 bolt
Yes.
Old Mar 12, 2016 | 11:21 AM
Car: 1988 IrocZ
Re: 10 bolt
Yes.
Ok thanks! You wouldn't know what these are worth would you?
Old Mar 12, 2016 | 11:36 AM
JamesC's Avatar
Re: 10 bolt
The 9-bolt (89) and the 10-bolt (90-92) rear with PBR's is more desirable than the 82-88 rears with Delco-Moraines. The gear ratio is also worth noting. One with highway gears, for example, wouldn't generally have the same interest as one with 3.23's or 3.42's. Same with open or limited slip. Worth? I can't really say. Perhaps a search will provide more info where price is concerned.
JamesC
Old Mar 12, 2016 | 11:38 AM
Car: 1988 IrocZ
Re: 10 bolt
The 9-bolt (89) and the 10-bolt (90-92) rear with PBR's is more desirable than the 82-88 rears with Delco-Moraines. The gear ratio is also worth noting. One with highway gears, for example, wouldn't generally have the same interest as one with 3.23's or 3.42's. Worth? I can't really say. Perhaps a search will provide more info where price is concerned.
JamesC
My buddy spun it and said it was in the 3.20s range
Old Mar 12, 2016 | 11:39 AM
JamesC's Avatar
Re: 10 bolt
To be sure, jerk the cover.
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Mar 12, 2016 | 01:28 PM
Car: 1988 IrocZ
Re: 10 bolt
If it happens to be the one, is there a ballpark estimate of what you think it could go for?
Old Mar 12, 2016 | 07:07 PM
JamesC's Avatar
Re: 10 bolt
Guessing only, $250-400.
JamesC
Old Mar 12, 2016 | 09:20 PM
dbrochard's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WC T5
Axle/Gears: Torsen 3.73
Re: 10 bolt
250 if it is posi and 200ish without in my opinion
Old Mar 13, 2016 | 12:44 AM
Night rider327's Avatar
Car: 1988 Camaro
Re: 10 bolt
Well it really depends on your local market. I just sold a '84 factory 3.73 non posi disk brake 10 bolt for $350 and a 9 bolt posi 3.27 w/o brakes and in need of cone shimming for $250
Old Mar 13, 2016 | 06:30 AM
truckerz's Avatar
Car: 1989 Formula
Engine: 355ci HSR SBC
Re: 10 bolt
Ditto Night Rider327. I'm in North GA, and I see them off and on between 200-350 depending on condition and if the brakes are intact.
aaron7
Interior Parts Wanted
17
Jun 5, 2016 06:41 AM
91banditt2
Brakes
Mar 18, 2016 11:22 PM
evo-offer
Mar 18, 2016 11:04 AM
dpmalibu
Mar 16, 2016 06:52 PM
zacharyhorn
Mar 12, 2016 09:04 AM
