Shifter bouncing up and down?
I have an 86 firebird 305, carburated. When i give it alot of gas the shifter will bounce up and down quite a bit and it will also lose power in sequence with the shifter bouncing. The power loss could be a part of another problem but im trying to figure out why its doint this. It also bounces over bumps to. It is manual transmission.
Car: Sport Coupe
Engine: 3.4 MPFI
Transmission: WC T5
Re: Shifter bouncing up and down?
when my first trans mount went, I still had the automatic. That thing was banging around like it was trying to escape.
Not a hard repair.
Not a hard repair.
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
It is four bolts and one nut on the brace and two bolts on the trans. Really simple to change with a ratchet and a jack to brace the trans.
Labour doesn't cost anything.
The part is around $12 for a stock one, just like the one you got now that broke, or maybe $20ish for one that won't do that again the first time you let out the clutch ... a little .... too..... ,,, .... ,, ............ enthusiastically.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Before you make a decision about mount types, you might pursue the following link:
https://www.thirdgen.org/forums/tran...ison-pics.html
JamesC
JamesC
Car: '90 RS, UH-60M
Engine: HSR'D 400
Transmission: TCI POS DONT BUY TCI!!!
Axle/Gears: Three2three
JamesC
JamesC
One caveat, I will never be able to shock the driveline with the worlds worst TCI 700r4 like you can by side-stepping the clutch.
