tcc
Old Mar 21, 2018 | 04:48 AM
onebdgti's Avatar
tcc
What is everyone doing about the tcc after removing the computer. I have a carbed 383 stroker going back into the car. Wondering if its worth to use the tcc or just leave it disconnected. The car will used on the street/strip.
Old Mar 21, 2018 | 07:20 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: tcc
Wire a manual toggle switch to the TTC. Don't forget to switch it off before coming to a stop or it will stall. Or just disconnect it and don't use lock up
Old Mar 21, 2018 | 07:32 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Re: tcc
My last car I went from TPI to carb and never did wire the tcc back. I never had issues but I didn't daily drive the car either. Made a few 100 mi trips though and a good many passes at the track. In saying that as a $100 insurance id probably go ahead and wire it up to a switch like Bob mentioned for long highway trips if nothing else.
Old Mar 22, 2018 | 12:44 PM
onebdgti's Avatar
Re: tcc
It is disconnected rite now. I may in the future hook it up to a toggle switch buy for now it will stay unplugged.
Old Mar 22, 2018 | 12:59 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: tcc
You can allways install a lockup kit.
https://www.summitracing.com/parts/tci-376600
Old Mar 22, 2018 | 01:06 PM
Engine: Lb9
Transmission: M20
Re: tcc
Here’s a schematic for tcc looks like lockup is power on the tan/blk wire.
Old Mar 22, 2018 | 02:13 PM
onebdgti's Avatar
Re: tcc
Thanks Tuned Performance. I found a post were i can put a vacuum actuator on it like a vacuum modulator that will lock it while cruising then unlock when WOT. It can also be locked in VIA a toggle switch and turn off when pressing the brake. Sounds a little complicated but once i lay it all out it shouldnt be to hard.
Old Mar 23, 2018 | 12:15 AM
NoEmissions84TA's Avatar
Re: tcc
I assume you know about the TV cable and TV correction brackets if you are using any other carb than a quadrajet?
Old Mar 23, 2018 | 05:46 AM
onebdgti's Avatar
Re: tcc
Sure do. I picked one up through Jegs.
Old Mar 23, 2018 | 06:56 AM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: tcc
I got a lock-up kit from Monster Transmission for $99.00 ...
Old Mar 25, 2018 | 08:08 AM
onebdgti's Avatar
Re: tcc
I thought about the lock-uo kit through monster but I wanna make sure that it will disengage when slowing down just in case I leave the switch turned on. There is a how to to make it vacuum operated and also work with the brake switch. There was a post about it let me see if I can find it.
Old Mar 25, 2018 | 08:30 AM
onebdgti's Avatar
Re: tcc
https://www.thirdgen.org/forums/tran...cc-lockup.html
This one of them I have found
Old Mar 26, 2018 | 03:22 AM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
Re: tcc
would you just wire the switch to give 12volts to terminal A?
Old Mar 26, 2018 | 08:14 AM
onebdgti's Avatar
Re: tcc
Looks like the control is the tan/black wire. Termiinal D
Old Mar 26, 2018 | 08:26 PM
Re: tcc
Referring to the diagram above, the way I read it, you already have +12 volts at terminal A via the brake switch. All you need to do is connect to pin F at your ALDL connector which connects directly to that tan/blk wire (D on trans connector). Run a wire from pin F to your added switch with the other end connected to ground. The brake switch will automatically unlock the TCC when you apply the brakes.
Old Mar 27, 2018 | 08:30 PM
Re: tcc
i have never wired a switch to complete a ground so this is probably a stupid question and i am probably over thinking this.
i have a 3 prong switch i can use. the 3 poles are labeled POWER-ACC-GROUND.
would i just take the wire from terminal F from the ALDL and connect it to the ACC switch pole then wire the GROUND switch pole to a chassis ground? and leave the POWER pole alone correct?
this is a lighted switch. is the POWER switch pole only for the light in the switch?
see attached pic.
Old Mar 28, 2018 | 01:15 PM
onebdgti's Avatar
Re: tcc
see attached pic.
The ground is so that your light will work on the switch
Old Mar 28, 2018 | 01:35 PM
Re: tcc
Ok so cut the wire going to terminal f on the aldl. Connect one side to power and the other side to the acc terminal and connect that to a chassis ground?
Old Mar 28, 2018 | 11:54 PM
onebdgti's Avatar
Re: tcc
Are you talking about terminal F on the schematic up above. If so terminal F looks like the up shift light.
Old Mar 28, 2018 | 11:59 PM
onebdgti's Avatar
Re: tcc
I see were you are talking Terminal F at the aldl. Thats were I figure it ties into. My car doesnt have anymore of that wiring left in it so I am gonna send power rite to the plug at the trans at terminal D in which thats were terminal F is tied into.
Old Mar 29, 2018 | 08:24 PM
Re: tcc
That switch you have normally switches +12v and the ground you provide to it lights the bulb inside. Right now I'm not sure if you can accomplish the same thing by switching ground instead.
Assuming your brake switch wiring is still present and working, +12v should already be present at terminal A of the trans plug. This also assumes that your car's wiring matches the diagram above. To complete the circuit, you need to provide a ground (through a switch) to terminal D to complete the circuit. If the ALDL connector is still present, then you can use the wire on pin F to connect to since it connects to pin D on the trans connector.
Old Mar 29, 2018 | 08:53 PM
Re: tcc
Tried this today and it didn't work. Tapped into terminal f and connected the other wire from the switch to a ground. Went for a drive and flipped the switch. Rpms didn't change at all. Will mess with it again tonight.
Also looked at my brake pedal, the switch for the tcc 12v is still there. I will make sure that is sending voltage as well.
85f-bird
Aug 11, 2004 09:27 PM
88irock
Dec 5, 2002 11:30 PM
CAPRICE9C1SS
Aug 8, 2001 02:50 PM
88gta305
Feb 1, 2001 03:48 PM
