what type is the GM VSS
Old Apr 13, 2018 | 09:03 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
what type is the GM vss ?
below to work with auto meter speedo
Speedometer Senders The speedometer is designed to operate with an electrical speed sender. The speed sender signal range must be between 500 and 400,000 pulses/mile (310 and 248,500 pulses/km). Any speed sender or electronic module that meets the following two conditions can be used: 1. Pulse rate generated is proportional to vehicle speed. 2. Output voltage within the ranges listed below: • Hall effect sender, 3-wire (5 to 16V) • Sine wave generator, 2-wire (1.4 VAC min.) • 5V Square wave (CMOS) Recommended – Auto Meter Hall effect sender, 3-wire 16 pulses/revolution. 5291 Standard 7/8 – 18 thread
Old Apr 13, 2018 | 09:20 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: what type is the GM VSS
I think yours is a magnetic pulse 4k ppm. If the signal needs to be changed for tire size gear ratio you can use a Dakota digital sgi-5 .
Old Apr 13, 2018 | 09:25 PM
thanks for the reply..
thinking of just installing auto meter everything../racepack type if I have to take it all out...
looking at what I would need..i want to leave my auto meter tach in it's place now..and install the speedo and other gauges in the dash face... not going to run the speedo and tach side by side....(like every body)
gear sets and tire size can be swapped in a day to what I want..
tire size in the 28 to 29" tall
have now 325/50/15
could go 245/45/17
4.11
4.56
4.30
Old Apr 13, 2018 | 09:34 PM
Engine: Lb9
Transmission: M20
Autometer sells Hall effect Vss sensors. You would have to convert to a cable drive instead of the Vss that’s in there now. I think it’s just a matter of changing the gear and housing.
https://m.ebay.com/sch/i.html?_from=...using&_sacat=0
You might want to check with autometer it might be considered number 1
Old Apr 13, 2018 | 09:50 PM
was thinking GPS type speedo..but cable would be fine also..
ill have to chat to them
want to keep it simple..
Old Apr 13, 2018 | 10:03 PM
Engine: Lb9
Transmission: M20
Looks easy to wire up . Power , ground and signal
https://www.autometer.com/media/manual/2650-1168.pdf
Old Apr 13, 2018 | 10:28 PM
I was looking at that..on there site..
could it be that easy?
not to see what drive gears/driven gears they have for my set up..
Old Apr 13, 2018 | 10:31 PM
Engine: Lb9
Transmission: M20
eBay and I think tci sells the drive and driven gears. With that many rear gear options a gps Vss might be the best .
Old Apr 13, 2018 | 11:10 PM
its what I was looking (GPS) $200 ballpark no biggy..but the reset on them is a snap.
Old Apr 14, 2018 | 12:55 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
4004 pulse per mile sine wave.
doc
Aftermarket Product Review
Apr 8, 2009 04:08 PM
tshack
Jan 20, 2009 08:52 PM
brian schuetta
Oct 8, 2006 07:29 PM
chevy power
Theoretical and Street Racing
23
Jun 6, 2002 08:10 PM
Jim85IROC
May 17, 2002 08:50 PM
