700r4 shifting hard 1-2
Old May 30, 2018 | 02:18 AM
Spooky3g's Avatar
Car: 89 Camaro
Engine: 5.7 carb
Just picked up my first 3rd gen a couple days ago. Wanting to figure out if the car actually has a built trans? Or if it's going or something inside needs replaced. Here's what's happening:
Accelerating slowly from a stop shifting out of first seems to take a minute if I let it rev up to 4kish it will shift into second roughly. If I accelerate slowly and sit at about 3k it will shift roughly as well. But if you go from a dead stop and accelerate hard it shifts like butter and kicks the tires out. Does this sound like built trans or an internal issue. Thanks. New to all of this carb/autotragic stuff.
Old May 30, 2018 | 02:51 AM
Spooky3g's Avatar
Car: 89 Camaro
Engine: 5.7 carb
Re: 700r4 shifting hard 1-2
Also 2-3 is significantly less rough but still kicks a little. 3-4 is not barely noticeable
Old May 30, 2018 | 03:49 AM
NoEmissions84TA's Avatar
First and easy to check is the TV cable adjustment.
Old May 30, 2018 | 12:14 PM
Spooky3g's Avatar
Car: 89 Camaro
Engine: 5.7 carb
Where is this cable located? New this this stuff.
Old Jun 6, 2018 | 02:26 PM
Hawgtied's Avatar
Car: 1988 IROC "The Duece"
Engine: 5.7 TPI L98
I had one years ago that had similar symptoms. One of the planetary gear sets had went out. I went ahead and had the whole thing rebuilt-no real choice in the matter. Hopefully yours is just a built tranny so you can enjoy it! please report back your findings
Old Jun 11, 2018 | 07:29 PM
Irocjay85's Avatar
Car: 85 z28 irocz
Axle/Gears: 4.10
I think Im having the same problem, I have an 85 iroc with a 700r4 tranny with 410 gears and I get a little bit of a whine from the tranny when accelerating, mine doesn't bang into second but it shifts fairly rough when it isn't warmed up. If I let it idle a while before I taker it out of the drive then it seem to be fine. Although after it warming up and driving down the road when I accelerate I can hear the tranny whining a little bitr almost like its low on fluid but it isn't, I have checked and double checked, were thinking maybe it is the tv cable possibly not mounted in the right place. My motor is a 350 with a lingenfelter short ram intake, the tv cable bracket looks like it may be a home made job from the builder but Im not positive. My father in law had read that the tv cable had to be down 1" and back 1/2" from the pivot on the throttle, can anyone confirm this to be true? and if so can you attach a pic for me to see?
Hope to hear back soon, also this is my first forum that I am apart of so if this issue doesn't make sense for this thread plz advise.
Cheers
Old Jun 14, 2018 | 02:36 PM
duanejangula's Avatar
Car: 1987 Camaro Iroc-z
Engine: 5.7L (350) TPI (dual fan cool
Transmission: Automatic 4sp (700R4 i bel)
hi: I have an 98 Iroc with 700r4 tranny, 350tpi.. Mine also shifts (should i say) fairly hard/firm from 1st to 2nd and also the other gears it's a very firm shift. I have not changed any trany fluid since i had it. I got this car last fall and worked on some other items. Now starting to think about the trany.
Any comments/suggestions etc would be greatly appreciated.
Thanks. Duane
Old Jun 14, 2018 | 03:25 PM
Irocjay85's Avatar
Car: 85 z28 irocz
Axle/Gears: 4.10
My father in law and I are checking the tv cable and tv cable brackets tonight, if there out of adjustment that will make it shift hard, I'm tearing my torque converter out and getting a rebuild done on it because of the whine in the tranny.
Old Jun 18, 2018 | 05:54 PM
The TV Cable. Can someone tell me if this cable is not properly adjusted, that damage could result to the tranny. Thanks.
Old Jun 18, 2018 | 06:04 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
There is a spring loaded valve in the valve body that regulates this shift it is probably sticking . TRy a complete fluid and filter change may fix it. If not get a manual and tear it down.
Old Jun 23, 2018 | 09:52 PM
Pro Built Automatics's Avatar
If the TV cable adjustment is correct, (Max TV at WOT throttle) and the part throttle shifts are happening at the right time (and the shifts are too firm), then the feed holes in the separator are most likely too large. On the 1-2 shift, the accumulator being restricted will bring on rough 1-2 part throttle shifts also.
Old Jun 1, 2022 | 12:20 PM
calidude's Avatar
Car: 1985 Camaro IROC
Transmission: Auto O/D
I know this is an old thread but I have an 85 with a 700R4 and getting a rough 1-2 shift and having the same as others where it works better once warmed up. It will screech tires on hard acceleration and jerk hard. I've already adjusted the TV cable and that didn't improve anything. Is there a maintenance item for the accumulator or something to resolve?
I'm assuming there is some kind of seal or rubber that could just be old...
Old Jun 1, 2022 | 12:32 PM
I have a 1987 with 700R4 and I have same thing, hard shifts between 1-2... I was just told that's the way they are.. After it warms up, shifts are a bit smoother..
Old Jun 1, 2022 | 02:26 PM
vorteciroc's Avatar
Top Answer: 1
Is this a new condition, a worsening condition, or an ongoing condition?
Fluid level and condition?
Any modifications made recently?
Mileage on the unit?
If this is anew condition and the Fluid is full and in good health...
I would like to see Line-Pressure readings, and know about any modifications made.
It is possible that the 2nd Accumulator Spring has broken/ corresponding Piston does not seal anymore.
Old Jun 1, 2022 | 02:29 PM
vorteciroc's Avatar
Top Answer: 1
The books that we (Hydra-Matic Engineering and Buick Engineering) wrote for GM Techs to Learn this Transmission used to be found on EBAY from time to time.
Not so much anymore though.
Digital Copies do exist for download; search for the THM700-R4 Principles of Operation/ Technician's Guide.
Old Jun 1, 2022 | 08:17 PM
calidude's Avatar
Fluid level and condition? Good and changed about a year ago with new filter.
Any modifications made recently? None, bone stock
Mileage on the unit? 95,000
If this is a new condition and the Fluid is full and in good health...
Thanks answers above and appreciate your in depth knowledge!
Another interesting thing I see on cold startup is the car actually seems like it moves forward a bit while in park. Not sure if that is related?
Old Jun 1, 2022 | 09:19 PM
vorteciroc's Avatar
Top Answer: 1
That would most often be indicative of a Clutch-Pack dragging...
The Forward Clutch for example in the THM700-R4.
Old Jun 1, 2022 | 11:57 PM
calidude's Avatar
okay thanks, any additional insight on the 1-2 shift?
Old Jun 2, 2022 | 10:40 AM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
Noting really wrong with a hard shift, if tranny has no problems, as u can adjust the hardness by adjusting the TV cable inward,
Old Jun 2, 2022 | 10:58 AM
calidude's Avatar
Thanks Gerry, yeah it improves on warm up... just trying to understand why it's an issue and what maintenance I would do to solve it
Old Jun 4, 2022 | 03:22 AM
Camaro71's Avatar
Thinking out loud: temperature related issues are related to hardened/hardening seals. Once oil is warmed up, the seals will soften and work correctly. Till this moment I can imagine leaking some oil and only shifting with more TV pressure/line pressure.
Old Jun 4, 2022 | 10:20 AM
calidude's Avatar
Yeah that makes some good logical sense to me, it’s a smooth shifting trans once it’s warmed up. Cars that sit and don’t get used just don’t run well I’ve found, gotta drive em
Any seal specifically?
Old Jun 4, 2022 | 12:58 PM
Camaro71's Avatar
In case of the 1-2 shift, I would be checking the 1-2 acc piston seal and the 2nd piston seal in the servo.
Old Jun 4, 2022 | 07:17 PM
vorteciroc's Avatar
Top Answer: 1
As I posted before...
I would start out by taking a look at the 2nd-Accumulator Parts.
Old Jun 4, 2022 | 07:37 PM
Also look to see if it has a B&M shift kit installed in it.
It's total crap; does that to make the n00bz that buy one and put it in, think that they've "improved" it somehow. Often ends up breaking parts. Main noticeable symptom of one is, EXTREMELY HARSH 1-2 shift.
Best way to find out would be, download the install instructions; and inspect your valve body closely to see if that's what's been done to it.
Old Jun 5, 2022 | 12:20 AM
vorteciroc's Avatar
Top Answer: 1
I second the "B&M Shift-Kit is Crap"!
I refer to that line of Products as the UnEngineered "Shift-Kit".
Actually, I don't even like the Term: "Shift-Kit".
Anyway...
A guaranteed sign of B&M Parts installed, would be a Spacer/ short piece of Tubing that replaces an Accumulator Spring.
Some Accumulation on the 1-2 Shift is a good thing!
Quick, Firm, Positive Shifting is what we want for long and healthy Transmission Life.
Overly harsh Shifts are unhealthy for the Transmission/ Unnecessarily breaks Parts.
The 1-2 Shift for this Transmission, can very easily be made very firm if desired.
There are several correct ways to go about doing so...
Then there is of course is the wrong way (B&M).
Old Jun 5, 2022 | 01:53 PM
calidude's Avatar
Thanks guys, been doing more study on this and guess the early versions of the 700R4 prior to 87 has some challenges
The spring can break in the 1-2 accumulator and seems there are lots of aftermarket pin delete piston kits too.
If I get ambitious may remove and inspect.
Old Jun 5, 2022 | 02:03 PM
calidude's Avatar
yes this, thanks!
R/T-Z28
Mar 3, 2013 06:17 PM
MaroNut383
Feb 10, 2006 08:20 PM
GASGZLR
Mar 10, 2004 03:04 PM
MrJ
Sep 20, 2000 12:16 AM
