Noise, rear end
Old Feb 3, 2019 | 01:05 PM
Haru's Avatar
Noise, rear end
Hard to explain but sounds like whoomp, whoomp..rotational sound, increases with speed of course. Put on jack stands put in drive and used stethoscope with no luck in duplicating the sound. Only when in drive and on the ground. 1991, Z28 350 and don't recall which rear end. Any suggestions and help is greatly appreciated.
Old Feb 3, 2019 | 02:04 PM
Re: Noise, rear end
Probably a 7½" 10-bolt. Virtually for certain.
Probably axle bearings. Pop the axles out and check. Since the axle is the inner bearing race, if the bearings are bad, the axles are almost certainly bad too.
Old Feb 3, 2019 | 02:10 PM
Haru's Avatar
Re: Noise, rear end
Thank you for the input, much appreciated!
Old Mar 31, 2019 | 01:31 PM
Haru's Avatar
Re: Noise, rear end
We replaced the Axles, ended up being bearings in the diff, so had it rebuilt. Again, thank you!
iroczrockz
Nov 21, 2002 08:38 AM
Hot Wheeler
Jul 30, 2002 09:34 PM
smoke the tires
Apr 10, 2002 04:45 PM
zimmer
Mar 26, 2002 11:24 PM
david foraker
Jan 23, 2001 04:47 PM
