speedo
Old Jul 15, 2020 | 07:08 PM
Jimmy DesPro's Avatar
Car: Camaro Iroc-z 1986-89-91
speedo
hi, i changed my speed cable because my needle went up and down suddenly, so i changed my speed cable. But now the needle goes up but does not indicate the right speed. So what is my problem other than my speed cable? Thank you
for camaro 1989
Old Jul 15, 2020 | 07:25 PM
Re: speedo
Has it EVER indicated the correct speed since you changed it to the 350/T-5 combo? What rear gears does it have in it?
Old Jul 15, 2020 | 07:29 PM
Re: speedo
Everything was working normally a week ago
Old Jul 15, 2020 | 07:30 PM
Re: speedo
only my RPM which indicates not the right one chosen but its another problem lol !!!
Old Jul 15, 2020 | 08:28 PM
Re: speedo
Does the car have cruise control? Does that have the regulator that looks somewhat like this? (screwed to the front of the driver's side strut tower)
The thing at the lower right with the wires that says things like "HOLD" and "ENGAGE"...
Old Jul 15, 2020 | 10:13 PM
Re: speedo
yes I have a speed regulator but which does not work, share against I do not have the connector that you show on the photo. to be on this connector is right next to the engine or under the dash
Old Jul 16, 2020 | 06:21 AM
Re: speedo
The thing that the wires in the photo plug into, is the cruise control regulator. In addition to the wires that turn it on and off it has one cable that comes from the transmission, and one that goes to the speedo in the cluster. In the photo you can see the threads where one of them screws on: the cable itself is just barely out of view of the camera I guess.
The regulator contains a copper disc that the cable spins. It induces a current in another disc, much the same way as the speedo itself works. When the regulator fails, the discs rub together instead of the one spinning right close to the other, and all sorts of bad things happen. It usually makes the cables bind and spin erratically, which affects the speedo reading.
Yours is probably bad.
Old Jul 16, 2020 | 07:44 AM
Re: speedo
My cable coming directly from the transmission goes to the cluster. I imagine that my problem comes more from the cluster since the cable goes directly there and that it is new. I don't think I have this sensor because I haven't seen it anywhere. do you have any other photo of its location and cables.
EMCC ROB
Mar 6, 2010 07:57 PM
roc88
May 31, 2006 01:11 AM
JamesC
Sep 20, 2004 08:14 AM
1fastgta
Mar 25, 2003 03:10 PM
1fastgta
Mar 19, 2003 02:36 PM
