What converter to go with?
Old Sep 4, 2020 | 11:51 AM
19Iroc-Z90's Avatar
Car: 1990 Chevy Camaro Iroc Z
Engine: 5.7L 350
Axle/Gears: Stock and 373
I am new to the page. I have 1990 Iroc-Z 5.7L. I have a Comp Cams 08-302-8 cam in it. I was wondering what torque converter I should go with and what brand?
Old Sep 4, 2020 | 06:15 PM
GeneralDisorder's Avatar
Re: What converter to go with?
Depends on what you want. I have a 3000 rpm converter on mine with 3.70 gears. But it's a built transmission and I have 350 HP at the rear wheels. If you are running stock heads and TPI you should probably stick with 2000 (S10 converter) or 2500.
GD
Old Sep 4, 2020 | 06:45 PM
ULTM8Z's Avatar
Frankly I wouldn't go lower than 2500 if you want to notice any significant improvement. I have a 2500 rpm in my TH700, 3.42 axle, modded ZZ4 with probably 420 ftlb of torque, ~3300-3400 lb car, and it'll flash to about ~2300 rpm.
But during normal driving, it drives completely like stock to the point that you'd never guess it has a non-stock converter in it.
Old Sep 5, 2020 | 05:49 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
That cam is only good from 1200-5200, something close to stock will do fine. At least get somewhere into the power like 1800-2000 converter
Old Oct 9, 2020 | 09:22 PM
BHR's Avatar
BHR
whatever you do ditch the heavy 12 inch
id go with a yank SS Series with a 2800 stall
Old Oct 10, 2020 | 10:23 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
S10 converter. You send $165 and you get 2300+- stall
Old Oct 10, 2020 | 11:57 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
2800
Old Oct 11, 2020 | 07:44 PM
S10 converter is too tight IMO. They creep forward with a cam and a little higher idle.
GD
Old Oct 12, 2020 | 07:42 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
GD
I agree with them being a lil tight on a "cammed" engine but tbh his cam is a very mild one, not much of a cam at all. I figured it would be a good fit. Maybe a 2800 would be better though.
Old Oct 13, 2020 | 08:11 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
No one bothered to ask him about the rear gears he has, be nuts to run a stall on a street driver with 2.77's. 2,73's, eh?
Old Oct 14, 2020 | 04:50 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
it says 3.73 under his name
Old Oct 14, 2020 | 07:43 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
not at all imo. It helps all cars
in fact my bolt on ls1 with 3200 was only .07 faster with 3.73’s vs 2.73’s, no other changes. Im sure some transmission tuning of the shift points could have optimized it more but 60 foot only was .05 better. Hardly a gain.
19Iroc-Z90
Sep 4, 2020 12:29 AM
brad_4291
Feb 7, 2011 12:43 AM
brad_4291
Feb 6, 2011 06:36 PM
