Dig delima here...
Old Jan 17, 2002 | 11:27 AM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
Dig delima here...
I'll have my TTA motor in about a week, i hope to have it in by March. I was planning on sticking with the 700r4 but the thought of converting to the 200r4 keeps creeping into my head, though its an expensive swap, what do u guys think?
Old Jan 17, 2002 | 02:13 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You'll have to convert to the 200-4r, the 700r4 won't bolt to the Buick 6-cyl block.
Old Jan 17, 2002 | 03:38 PM
Ions91Z28's Avatar
Car: 1991 Camaro Z28
Really? I have a friend that just bought a TTA motor... as well. There is no way to get it to bolt to a 700r4?
Old Jan 17, 2002 | 05:12 PM
transfixleo's Avatar
You could probably use various adapters but you more than likely wouldn't like how it would work. I suspect one of the reasons the 200-4R was selected by GM was that it has a closer ratio and thus the turbo will stay 'on' when accelerating at heavy throttle.
Old Jan 17, 2002 | 06:04 PM
fly89gta's Avatar
Car: 2018 Camaro SS
TCI makes an adapter plate that allows a 700r4 to bolt to a buick 3.8.
Old Jan 17, 2002 | 06:14 PM
Tallboy's Avatar
why a buick 3.8?
couldnt u use a 3.8 from say an 85 bonneville?
or does the bu have a lesser compression ratio??????better heads???cam???
Old Jan 17, 2002 | 06:56 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Originally posted by Tallboy
why a buick 3.8?
read above, i have a TTA motor on its way.....the TTA motor is a buick motor
Old Jan 17, 2002 | 11:51 PM
Ions91Z28's Avatar
why a buick 3.8?
I've heard the standard 85 buick engine is the same as the GN motor... except different components. Block is the same, except you have to drill a different hole or something somewhere. Might want to check on a GN board about that.
Old Jan 18, 2002 | 08:00 AM
fly89gta's Avatar
Car: 2018 Camaro SS
the block might be the same as an 85 GN engine but i think the block changed slightly in '86/87. Don't quote me though......
morrow
Jan 13, 2024 12:29 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
92GTA
Apr 9, 2016 07:39 AM
83 Crossfire TA
Sep 8, 2015 12:06 PM
FireDemonSiC
Sep 3, 2015 12:31 PM
