700r4 tranny fluid capacity question
Old Aug 17, 2021 | 11:51 AM
cjpenny89's Avatar
I am adding a TCC lock up switch in my 1984 Camaro with 700r4 tranny. I bought a filter kit and drain plug kit along with my TCC lock up components from TCI automotive. I am going to pull the pan tonight and let is drain so I can change my 4th gear pressure switch and 2 wire solenoid. Once I bolt it all back up how many quarts of tranny fluid am I going to need? Napa says 11 quarts of Dex VI at $8.99 a quart.
Is this tranny really going to use 11 quarts after dropping the tranny pan? I am assuming 11 quarts fills the torque converter as well? Also is Dex VI compatible with what might be in my tranny now?
Old Aug 17, 2021 | 12:30 PM
wlink14's Avatar
Car: '87 TA
Engine: 6.0LS
Transmission: 4L80e, 3000 stall
Axle/Gears: DIY 9 inch, 3.00 gear
Re: 700r4 tranny fluid capacity question
The DEX VI fluid supersedes all previous GM trans fluids. It has better lubrication properties. A pan drop will use somewhere between 4-6 quarts. Dump 4 in, start the car and let it idle for a minute. then check and add if needed.
Old Aug 17, 2021 | 12:52 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
You can get Dex 3 for half the price...
Old Aug 17, 2021 | 12:57 PM
cjpenny89's Avatar
thanks
Old Aug 17, 2021 | 05:01 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Dexron-Mercon is cheap, available, and will work just fine.
Jumping to VI won't gain you anything.
Old Aug 18, 2021 | 06:31 AM
cjpenny89's Avatar
sounds great
Old Aug 18, 2021 | 08:09 AM
2irocs's Avatar
Car: 1989 Iroc Camaro
Engine: 383 Stroker-Carb Blue Print Engine
Transmission: automatic
I pulled my 700r4 from my 89 Iroc last month had to put a new trans pump gaskets on...I did as wlink posted and put 4 quarts in trans let trans warm and then checked fluid and add as needed...
Old Aug 18, 2021 | 08:28 PM
vorteciroc's Avatar
Top Answer: 1
Dex-Merc (Dexron-III/ Dexron-Mercon) is actually a great ATF, that can and should be still used today.
Semi, and Full Synthetic Formulations are widely available for improved and/ or extended service.
The Main reason why GM released Dexron-VI is because GM started using ZF Automatic-Transmissions (6-Speed: 6L Family).
The ATF was produced to comply with the needs/ requirements of the ZF design Transmissions.
If any of you are not familiar... both GM and Ford (Examples: GM 6L80E, and Ford 6R80) entered into agreements with ZF to use the 6HP Transmission Family Units and Designs.
Ford essentially uses an identical ZF 6HP26 Transmission in their Vehicles but with a Bell-Housing that Mounts to Ford Engines.
GM on the other hand... Changed a significant amount of the 6HP26 Transmission (actually making it worse).
Dexron VI in GM Transmissions that pre-date the Fluid...
Behave for the most part the same as when using Dexron-III.
The Friction-Modifiers make for one of the three only noticeable differences.
When switching to Dexron-VI; I find that there are slightly firmer Shifts for a given Separator-Plate Orifice.
So I would step down Orificing sizes, one step in most Builds with Dexron-VI vs Dexron-III.
Otherwise I regularly see a small improvement in Fluid Temperature...
However the results are within the margin of errors for the Data.
Lastly I see the Fluid darken sooner than Dexron-III, but with no ill-effects.
Kaas
May 25, 2004 07:08 PM
trans87
Jul 10, 2003 03:30 AM
SHAGME
Apr 14, 2003 07:34 PM
lancer5067
Sep 30, 2002 10:15 PM
COUGAR
Sep 19, 2000 02:26 PM
