will this fix tranny mount?
Old Jan 19, 2002 | 10:34 PM
breathment's Avatar
ok, im tired of the constant vibrations while driving and the annyoing extreme vibrations at high RPMS at the shifter consol. i have replaced the rubber mount with a poly one. at first i DIDN"T put on the ("spacer")preload plate, and had vibrations, so when i changed the tranny fluid, i put the plate on. vibrations are a little better, but still really bad at high RPMS.
so heres what im thinking, goto autozone, pick up a rubber mount, drive around with that for a little while making sure nothing is screwed up after putting on the poly unit. then taking off the rubber one, placing it next to the poly on, and grab a hack saw and cutting the poly mount to the shape of the rubber one. that way its the same size.
any ideas\thoughts\opinions??
Old Jan 19, 2002 | 11:13 PM
ChevyLuva3's Avatar
Put on one stock rubber mount on one side, and another poly mount on the other, get the best of both worlds... I dunno man, check to see your drivetrain is balance.
Old Jan 20, 2002 | 02:19 AM
Jza's Avatar
Jza
What brand is your poly tranny mount? You won't be able to cut an Energy Suspension mount, it's got metal internals. Just put on the rubber mount (they're what, 6 bucks?) and see if it's better. I don't think that's your problem. BTW, you HAVE to use the preload plate. It's not a spacer.
Old Jan 20, 2002 | 11:49 PM
breathment's Avatar
well the energy suspenion mount has two little humps on the bottom of the mount.. im thinking they MIGHT be able to be cut..
Old Jan 21, 2002 | 12:12 AM
86_Dan_Z28's Avatar
Car: 86 Z28
No you don't. I use the mount without the spacer and it works fine.
Old Jan 21, 2002 | 12:23 AM
breathment's Avatar
i know the rubber ones have a plate, its just attached to the mount.
Old Jan 21, 2002 | 06:00 AM
Brian Shaughnessy's Avatar
Car: '89 Formula
Engine: 355 TPI
Axle/Gears: 3.70 9 bolt.
You can always try to get the rubber 1LE mount. Go to the store and ask for the mount for a 4th gen with a T-56. They'll probably have to order it but it's a compromise between vibration and strength.
Old Jan 26, 2002 | 06:40 PM
BlackBird91's Avatar
I just got the Energy Suspension mount and took down to the dealer and had them pull a stock trani. mount, the energy susp. mount is 1/4" taller then the stock one and that was with the upper preload plate. What I did was go the a local electical motor shop and get 4 - .25" motor mount shims and put them between the crossmember and the frame. It works like a charm and I matain the manufactures requirement to use the preload plate.
Old Jan 27, 2002 | 12:50 AM
Jza's Avatar
Jza
You do have to use the plate. Here's an analogy. Way back in grade school, did you ever play the game where you take turns hitting each other's pencil and try to break it? Now, did you ever try to cheat by bending your pencil so it arc'd upwards and made it harder to break? This is sort of the same thing in the mount. The preload plate pushes against those two humps and accomplishes the same effect.
Old Jan 27, 2002 | 01:04 AM
breathment's Avatar
well. that makes some sense.. so i should just go with putting spacers on the cross member thingy
Old Jan 27, 2002 | 01:13 AM
Flash84Z28's Avatar
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
The ES poly mount has to use the pre-load plate. That is NOT a spacer and the mount will not funtion correctly without it. It was designed for those two humps to rest against it. I don't know about shimming the x-member, I put mine in and it works fine (after grinding the hole in the x-member bigger of course). I do know that you can't cut the mount though, it's not just a block of polyurathane, inside there is a safty interlock and other metal supports that steangthen the mount.
-Matt
Old Jan 27, 2002 | 10:25 AM
JAY87GTA's Avatar
We went through this a few years ago. One of the guys from the old board e-mailed ES and they told him that the preload spacer wasn't necessary. If you're pushing big time power it's recommended, but for most applications its not necessary. I've got the spacer in and shimmed the crossmember down, seems to work pretty well.
WIzmo
Aug 30, 2015 02:30 PM
Thornburg
Aug 25, 2015 01:46 AM
spaigo
Aug 21, 2015 07:46 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
