Every gear goes forward like it’s in drive
Old Aug 14, 2022 | 05:03 PM
zac harris's Avatar
1991 trans am stock automatic transmission
It drove fine yesterday but now every gear is like it’s drive. Pulled the pan off and linkage shifts okay. Not too sure where to go from here if anyone has any ideas?
Old Aug 14, 2022 | 06:34 PM
vorteciroc's Avatar
Top Answer: 1
Re: Every gear goes forward like it’s in drive
Do you mean that when the Gear Selector is in:
-Park
-Reverse
-Neutral
That the Transmission operates as if the Gear Selector is in OD?
Or...
Do you mean that when the Gear Selector is in D1, D2, and D3...
Old Aug 14, 2022 | 07:54 PM
zac harris's Avatar
-Park
-Reverse
-Neutral
Or...
when reverse and neutral are selected the transmission still operates in drive
Old Aug 14, 2022 | 09:04 PM
Help us understand here:
What position is the actual transmission shift linkage in when this is going on? As in, you put the "handle" inside the car into whatever, and the transmission just carries on as if you hadn't done a damn thing?
Afterwards, when you got up under it and watched the transmission linkage as your assistant moved the handle from here to there, what did you see? Did you see the linkage go from D to R to P to L to whatever, or, ... what?
Old Aug 14, 2022 | 09:26 PM
vorteciroc's Avatar
Top Answer: 1
If the Linkage is operating properly...
Either the Manual Valve of the Valve-Body, is disconnected from the Linkage, or the Manual Valve is Broken, or the Valve-Body has a Cross-Leak/ Damage.
Old Aug 15, 2022 | 05:15 AM
Drew's Avatar
Too many neutral drops, or aggressively rocking a car stuck in snow, will do that. "Rocking" the car will sometimes break them loose again. It should be a death sentence for a 700R4 but I had one do that, and it went 7 more years of daily driving after getting it unjammed.
Old Aug 15, 2022 | 02:45 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
or the forward sprag is gone
Old Aug 15, 2022 | 03:24 PM
vorteciroc's Avatar
Top Answer: 1
If the Input Sprag Fails...
The Trans will operate NORMAL with the exception that there will be no 3rd or 4th Gear operation.
The Gear Selector operation would be perfectly fine.
Old Aug 18, 2022 | 11:27 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
The 4L60E in my 99 Tahoe failed in this manner. It welded clutches together when it started to slip. ALL gears were forward.
kissedin
Sep 2, 2012 10:08 AM
BG84FBIRD
Jan 6, 2009 04:48 AM
Teds92RS
May 10, 2006 05:06 PM
thechristopherh
Oct 27, 2003 03:18 PM
crazeinc
Oct 5, 2002 07:48 AM
