T5 questions
Old Nov 28, 2024 | 06:24 PM
David Fite's Avatar
Car: 1986 IROC-Z
T5 questions
Can anyone verify that this is a Camaro T5? Some guys in Facebook are saying the shifter on this looks like a Ford? The number on the sticker points to an 84 Camaro by my googling. Just want to make sure this is legit before I start prepping to do my swap. Could it be the shifter is just some non factory shifter?
And if it IS a Camaro T5, can I just order whatever shifter I want? Or do I need to get a stock one? I know nothing about these.
Old Nov 29, 2024 | 06:12 AM
Re: T5 questions
I see a Chevy V8 bell housing and a F body torque arm mount. So yeah ...
Old Nov 29, 2024 | 09:36 AM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Re: T5 questions
X2
Depending on what you're putting it in, you may want to verify that the gear ratios are what you want.
Old Nov 29, 2024 | 12:15 PM
stew'86MCSS396's Avatar
Car: '86MCSS
Engine: 396 .030"
Transmission: M20
Re: T5 questions
I tried to edit my post to show differences and messed up my post...click below...
Chevy Frod tail housing
Old Nov 29, 2024 | 01:37 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: T5 questions
84 F-body, 2.95 1st, 0.73 5th.
Good choice for a SBC.
Old Nov 29, 2024 | 01:48 PM
jmd's Avatar
jmd
Re: T5 questions
QUOTE=David Fite;6548741]And if it IS a Camaro T5, can I just order whatever shifter I want? Or do I need to get a stock one? I know nothing about these.[/QUOTE]
The F-body shifter for the T5 was closer to being a square than the Ford shifters.
The best Hurst is discontinued. I think they still have a Billet model that should be good. I also would consider Core Shifters, who favor Hurst designs.
And looking at yours, it's not a stock 84 shifter. If it's splined on one side (typically Hurst), that's good. Maybe it's able to be lubed or disassembled and lubed. Non splined sticks are lame.
Old Nov 30, 2024 | 01:30 PM
Gordon G E's Avatar
Car: Got me a nice little '86 Z28.
Engine: A brand new 350 with a forged lower
Transmission: 5 speed, TKO600.
Axle/Gears: 10 bolt 373 modified zexel.
Re: T5 questions
Looks like a Hurst to me.
Old Dec 5, 2024 | 05:06 AM
ZaraWhite's Avatar
Re: T5 questions
You have a Camaro T5, but the shifter could be aftermarket, which is why it looks like a Ford one. You can order any compatible shifter for a Camaro T5, but keep in mind that some may require slight adjustments for proper fitment. I needed professional assignment help and turned to https://ukwritings.com/assignment-help ukwritings. The service was outstanding from start to finish. The assignment was well-written, thoroughly researched, and free from errors. The writer followed my instructions carefully, ensuring the final product met my expectations. The work was delivered on time, making the process stress-free. I’m extremely satisfied with their service and highly recommend it to students looking for reliable academic support.
I also think that.
Old Dec 5, 2024 | 07:42 AM
David Fite's Avatar
Car: 1986 IROC-Z
Re: T5 questions
Thanks for the input guys. I have it in the shop right now getting some other stuff looked that, that I just don't have time to do... if all goes well the T5 will be on the list to do next
Old Dec 5, 2024 | 12:00 PM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: T5 questions
Reach out if you have questions, I did this swap a couple years ago and things are mostly still fresh
Old Dec 5, 2024 | 12:20 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: T5 questions
I just swapped my friend 86 in may easy enough swap.
85Iroc-Z
Jul 28, 2010 08:44 AM
1991_305RS
Sep 1, 2009 03:12 AM
black & gold
Apr 18, 2004 10:23 PM
