87 GTA 9 bolt question
Old Jan 14, 2026 | 05:59 PM
87gtaredonred's Avatar
Hey guys not sure if I screwed up. I swapped out the axle bearing on my passenger side went pretty straight forward. My issue is I can't get the axle shaft all the way back in. I've rocked the other wheel some hoping it would mesh but its in like 95% in if im making sense. What else do I need to do or did I screw up, never did this before. Thanks in advance!
Old Jan 16, 2026 | 08:22 PM
Don Fetherolf's Avatar
Car: 1989 Pontiac Firebird Formula 350
Engine: 5.7 TPI
Axle/Gears: 9 Bolt 3:27
Re: 87 GTA 9 bolt question
Did you match up the new bearing to the one removed? The new bearing could be wider and is bottoming out in the axle housing bore.
Old Jan 17, 2026 | 07:18 AM
Yes is the correct bearing Timken Set9, it was same size.
Old Jan 22, 2026 | 08:37 AM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
Make sure the bearing and collar are pressed all the way on. to the axle The other thing it could be is the posi cone and spider gear splines are not lined up. With the transmission in park or in gear (immobilize the driveshaft), hold the opposite wheel still and while installing the axle, when it doesn't want to go any further, turn the axle a little bit to rotate the posi cone and line up the splines with the spider gear. Depending on how good the posi is, it may or may not take some force (2' breaker bar between the lug studs will do it).
Old Jan 22, 2026 | 01:43 PM
Yes the bearing is all the way pressed on well it went to the edge and its where the old one was lol. I pulled up the parking brake the one side is locked down now I noticed when i bar over the axle the carrier is still turning I think i need to have someone hold down the carrier while I bar over the axle now, just need to find a friend lol. Hoping that's my issue. At least ive taught myself a ton about these 9 bolts
87gtaredonred
Dec 3, 2024 09:53 PM
zed-028
Apr 22, 2018 06:07 AM
white85transam
Apr 29, 2016 01:30 PM
87GTA518
Dec 4, 2006 01:35 AM
Ian_F
Apr 5, 2004 09:22 PM
