backing plates for 9 bolt
Old Feb 15, 2002 | 10:01 PM
5 litre eater's Avatar
Car: '84 Trans Am
Engine: 350ci Sportsman heads, B&M blower
Transmission: Turbo 350
would backing plates off any other rear end work, or are 9 bolt backing plates a special breed?
Old Feb 16, 2002 | 12:05 AM
TexasLT1's Avatar
Car: '92 RS
Im about 90% sure they are the same, but Im not positive. Ive got a 9-bolt up at the shop, and Ive got some 10 bolt backing plates here, but its too late to go up there and check. I'll find out tomorrow if no one else knows by then.
Old Feb 16, 2002 | 04:19 PM
Car: '84 Trans Am
That would be great! Thank you
Old Feb 16, 2002 | 05:40 PM
u r sofa king we tah did's Avatar
i modified 9 bolt backing plates to work on a 10 bolt disc rear, it would be alot harder to modify the 10 bolt backing plates to work on a 9 bolt rear. what are you trying to do.
Old Feb 16, 2002 | 06:33 PM
Car: '84 Trans Am
Well I blew my 10 bolt, but I have found a complete 9 bolt for a good price minus an axle and backing plate.A buddy of mine will sell me a pair of axles, a spare posi unit and 3.27 gears for $100(can.).I don't see how I could let this one go,but I can't find a backing plate anywhere.What to do?
Old Feb 16, 2002 | 10:25 PM
Eightyninef's Avatar
I'll sell you 3:27's for US$25.
Old Feb 17, 2002 | 03:40 PM
Car: '84 Trans Am
I've got 3.45s, so at this moment I need a backing plate more than some 3.27s.
Old Feb 17, 2002 | 07:26 PM
TexasLT1's Avatar
Car: '92 RS
well, as far as I can tell holding them up to each other, they are the exact same. so Id say go ahead and use them. if they wont work, let me know, Ive got two from both rears that Im trying to get rid of.
Old Feb 17, 2002 | 07:38 PM
strange, i just swapped from 9 bolt to 10 bolt, both big disc rears, and the backing plates were completely different.
Old Feb 17, 2002 | 08:37 PM
Car: '84 Trans Am
Well I guess I'll have to find out for myself. Thanx for your help guys.
Old Feb 18, 2002 | 12:30 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
I've got some pre 89 backing plates. email me if your interested.
Miles
Old Feb 18, 2002 | 06:23 PM
Mark 89Formula's Avatar
The bolt pattern is different. I just replaced a 9 bolt with a Dana 44. The 44 has the same hole pattern as the 10 bolt so I ordered a set of 90-92 10 bolt disc backing plates from the local GM dealer for a completely no-mod bolt-on install.
Old Feb 18, 2002 | 08:07 PM
farm-kid/88camaro's Avatar
i had 10 bolt backing plates and they wouldnt fit my 9-bolt. Had to hack em all up to fit.
Anyone know a part number for the 9-bolt ones?
Old Feb 18, 2002 | 11:09 PM
TexasLT1's Avatar
Car: '92 RS
well ****, I got completely screwed then. I bought what was supposed to be 89-up 10-bolt rear parts, axles, calipers, everything except the housing and diff. well now that yall say that, I guess the ******* sent me another 9-bolt set. DAMNIT!!!
Old Feb 24, 2002 | 11:32 PM
82 TRANS AM's Avatar
Car: 82 T/A WS7
Engine: Pontiac 400
Transmission: Muncie 4-speed
I have pre '89 backing plates too. I decided to use my dependable ten bolt drum brakes on my nine bolt, rather than the extrmely expensive and touchy pre '89 disk.
Old Feb 25, 2002 | 07:42 AM
irocnroll89's Avatar
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
I AM not sure what you were looking for..... i have a set of 10 bolt pre 89 disc brake backing plates, and a set of 89 9 bolt/90-92 ten bolt backing plates. As i am sure you know the 9-92 PBR brakes are the same, i just bought them to put my 9 bolt brakes on a 10 bolt, then blew it up AND went back to the 9 bolt SHAGGY
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
mhatfield 14
Oct 24, 2015 07:48 AM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
