Take a look.
Old Mar 6, 2002 | 04:40 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Take a look.
Well I went to dig my extra gear set out of the shed and this is what I found. Can I still use these?
Looks like only three teeth have slight pitting.
Any help would be great.
Thanx,
Rick
Old Mar 6, 2002 | 07:18 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
ttt
Old Mar 7, 2002 | 01:04 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Anyone?
Old Mar 7, 2002 | 01:08 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
You might clean them up with some emory cloth.
I dont know if it would cause any wear or not on the ring gear.
I would clean them up and see how they look. If the pits are not bad I think the gears should be oK.
just my .02 cents. Good luck.
Old Mar 7, 2002 | 01:23 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Thanx buddy, Guys around here are saying the same thing, just wanted to see what other guys had to say, ones with experience.
Old Mar 7, 2002 | 05:30 PM
ingar, norway's Avatar
Have a look at http://www.ring-pinion.com
Lots of useful information there.
Old Mar 8, 2002 | 02:52 AM
cac91's Avatar
I would only use them if you are looking at having them in thetre short term. From the picture it looks like the corrosion on the teeth is actually pretty good and aside from that, it looks like they had quite a bit a funky wear on them. So if it's temporary, sure, clean them up and put them in. Just don't expect them to be a long haul item.
Old Mar 8, 2002 | 10:28 PM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
I would have to agree with cac91. I wouldn't go through all the trouble changing gears, and use those. Not when motives can be picked up on the net for 150.00 or less. But if you like to change gears, use um.
Street Lethal
Apr 30, 2019 12:14 PM
86White_T/A305
Mar 6, 2016 01:48 PM
tglennon11
Sep 23, 2015 05:30 PM
david068513
Sep 18, 2015 10:36 AM
duke_mushroom
Nov 15, 2001 09:13 PM
