Which Posi unit??
Old Mar 25, 2002 | 10:51 AM
PopaPork's Avatar
Which Posi unit??
Hey I planned on gettin a SLP torsen posi unit for my car. Then last night I heard a few horror stories about them. Whuts all your takes about it? Are they good for the bucks, do they suck? Whut would you guys put in your cars? I dont really want to spend 300 + for a unit though. Thanks
Old Mar 25, 2002 | 01:31 PM
Momar's Avatar
They are the same units that they put in the brand new z28s and T/As. There is a stronger unit put in if slp does the car as an SS or WS6 though I believe. That should mean that they are good up to at least 310 probably more. I dont have experience with one, but I know that several people on this board do so someone else who has used it might chime in. Oh, and one thing I have heard is that slps shipping sucks and that the stuff is not packaged very well.
Ben
Old Mar 25, 2002 | 10:23 PM
RICHRAD's Avatar
What horror stories?.... First I've ever heard on those posi's
Old Mar 25, 2002 | 10:49 PM
PopaPork's Avatar
BlackBird305 just toasted his and it is only 11 months old. And he told me one of his buddies who had it toasted his in under a year to. We are starting to think he had to much Hook off the line. So who knows.
Old Mar 27, 2002 | 10:28 PM
wiesman's Avatar
I ordered a Torsen take-out from SLP. When it arrived (on time) it came in a box that was in really tough shape. maybe it was SLP, maybe it was UPS.
Last Friday I pulled the stock carrrier out and lined-em up. The stock carrier won. The ring gear mounting flange is much thicker. Now on the 7.5 10-bolt we all know that the ring gear just isn't the strongest piece around. I at least want to bolt it to something with some meat.
Yesterday a friend of mine asks how the build-up is going and we discuss the torsen. He informs me that they did a shoot out awhile back in a mustang magazine and the torsen does not fair well in dragstrip (slicks) applications. It seems without clutches there isn't any way to absorb shock within the differential. It all makes perfect sense now that I'm looking at one.
The moral of the story is always send it back in the same crappy box it came in.
Old Mar 28, 2002 | 02:38 PM
Lurch's Avatar
Will the unit survive on a mostly street driven car with under 300hp that will never use slicks?
I/ll be adding more power(250hp if I'm lucky) and a stick(T5) here pretty soon as well as 3.42's and a posi. So I don't want something that will die in less than a year.
Old Mar 28, 2002 | 02:44 PM
Dustin Imports's Avatar
Car: 1988 Medium Orange Metallic IROC
Transmission: 700R4 transgo shift kit
Axle/Gears: 4.10 in box lol
I have an Auburn Unit and Ive had no problems with it...its cheap and it works great.
Old Mar 28, 2002 | 09:30 PM
RSRagtop's Avatar
I think the SLP posi will work great for a street car. The factory carrier make look stronger. But it didn't roll of the assembly line behind 305 hp LS1. Plus, the weakest part of the stock carrier is the cross pin, which the Torsen doesn't have. I remember a Car Craft giveaway LS1 T/A, it had nitrous, slicks and other goodies. What went first? The clutch. I don't think they even touched the rear end. JMO
Old Mar 28, 2002 | 09:36 PM
jamesbern's Avatar
I've been thrashing mine for a couple of months now with no problem, for $100 who cares buy two and forget about it. Seriously, you will probably never touch it again if you car is strictly street use. I will be putting slicks on mine next week and kissing my 7.5 goodbye.
Old Mar 28, 2002 | 10:35 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
I'm probably getting the SLP unit myself, but I have a question in relation to the gears I want to put in.
I would like to put in Richmond Gears 3.23's (49-0044-1 @ $190) for a 3 series carrier. The thing is, when you look at the technicals it says 27-spline??? I know mine has a 28-spline....does this mean anything?
Also, it states "fits 3.23 and numerically higher carrier," soooo that's o.k. for the Zexel-Torsen right, because it's a higher carrier??
I'm more confused now than when I first started typing.
Old Mar 29, 2002 | 07:46 AM
82camaro's Avatar
Car: 82 camaro SC
If you are talking about gears and splines, they don't care about axle splines--it doesn't matter. You probably saw the splines on the pinion.
Old Mar 29, 2002 | 07:54 AM
PopaPork's Avatar
Good info. Keep it coming.
Old Mar 29, 2002 | 08:25 AM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
i know you said that you don't want to spend 300+ for a new one. i just got the auburn high performance series posi (cone style) for $304 from jegs. i did the install myself. it was a direct bolt up. i had no problems with the it. i have been driving ever since and i haven't had a problem.
Old Mar 29, 2002 | 10:26 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I can also confirm that the zexel torsion posi is a great unit. I am sure that it has some disadvantages, but you can't beat the bang for the buck!
92projectcamaro
Dec 8, 2015 12:25 AM
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
tattmann
Sep 27, 2015 05:20 PM
ironbmt
Sep 27, 2015 06:00 AM
