SLP Posi, why so cheap?
Old Apr 12, 2002 | 07:23 AM
deadtrend1's Avatar
I don't get it ..... I bought the SLP posi for my 91 firebird. I love it. But why was it so cheap when compared to Auborn posi units that are $400.
I know the basics of it. Same one as in new Z28's and Trans Am's. Its used only for 89 and up (28 spline axles and its carrier 3). My friend wants a posi and doesnt want to spend so much on it for his 87. And i told him unless he swaps out the axles to 28 spline hes SOL.
So what is the gain of spending the $300 more on the other units?
Old Apr 12, 2002 | 08:18 AM
Ringmaster72's Avatar
Car: 1989 IROC
The SLP posis are take offs. This means that they are taken out of the new camaros while they put a better one back in. The difference is the one they put in is stronger and a better unit.
Tim
Old Apr 12, 2002 | 10:58 AM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
huh............years ago when i talked to slp about posi units they told me to go to reider racing for an auburn.........?
Old Apr 12, 2002 | 01:19 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
I have a 89 Bird, how much can I get the posi for?
Old Apr 12, 2002 | 01:29 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
They sell for $99, I believe, check www.summitracing.com and do a search.
Old Apr 12, 2002 | 01:47 PM
deadtrend1's Avatar
No .. not summitracing. SLPONLINE and use model number 64501T.
~Tim
Old Apr 12, 2002 | 03:39 PM
Cool I have 100 buck to blow to make both wheels spin!
Old Apr 12, 2002 | 04:19 PM
89Formula305's Avatar
hah i had posi stock..
Old Apr 12, 2002 | 04:44 PM
Really! sux to be me... I have to pay 100 bucks
Old Apr 12, 2002 | 04:53 PM
deadtrend1's Avatar
going to cost another 100 to have someone install it unless you want to do it yourself. I had the gears all changed and i was without a depth setter, nor have the coordination to figure it all out. So, i let someone do it for me so i wouldnt be driving down the road, have a bolt fall out or something and have the rear end lock up. Thats my luck.
~Tim
Old Apr 12, 2002 | 07:46 PM
e-man's Avatar
Car: 89 formula
Engine: 383
Better check your prices I cant find good shop that knows what their doing in NJ to do a gear swap for less than $500!
Old Apr 13, 2002 | 02:00 AM
IROC-Z4ever's Avatar
Car: 1986 IROC
Transmission: TH700r4
Are those good?? I am looking to upgrade my rearend on my 86 IROC. yes I saw i need to change to 28 spine.
Old Apr 13, 2002 | 08:55 AM
Mutiny32's Avatar
Car: 1992 Camaro RS, Teal
Engine: 305 TBI, Soon to be 383 HSR
Transmission: Pro-Built 700R4
Mitnick?
I'm seriously wanting to buy this unit.
Old Apr 13, 2002 | 02:07 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Would an 89 firebird 305TBI have 28 spline axles?
Old Apr 13, 2002 | 02:30 PM
This site from deadtread's post says it does
http://www.slponline.com/view_produc...TNUMBER=64501T
>I shouldnt have a issue with installing the gears. I whatched my Bro take apart a possi rear end and show me what all the **** in there does. I'll just get his help, hehe lucky me.
>who is Kevin and why does he need to be free?
Old Apr 13, 2002 | 04:34 PM
deadtrend1's Avatar
Actually, it costed me 250 to get the posi and gears swapped out. Would be 100 if he didn't have to do the gears. Place is in south jersey near the betsy ross/ tocony palmyra bridges. If you ever need to know I'll give you the name of the place.
Old Apr 13, 2002 | 08:48 PM
Car: 1986 IROC
Yes Kevin Mitnick, he is out of jail but he is still on Probation. He was the Notorious computer Hacker.
Old Apr 15, 2002 | 01:17 AM
IROCZ88's Avatar
Oh, I thought you were talking about Kevin Harvick.
Old Apr 15, 2002 | 02:56 PM
BuddyLeeX's Avatar
Car: 06 Toyota Tundra SR5
I have an 87 and I want posi but I guess I dotn have a 28 spline axle. How much are axles?
Old Apr 15, 2002 | 03:05 PM
82camaro's Avatar
Car: 82 camaro SC
You have other options. Powertrax costs more money, but you don't have to set-up the gears(probably can install yourself or much cheaper to have it done), won't have to install bearings, and it will work with the older 26 spline axles(no axle cost). After all that, the extra cost of the powertrax isn't much.
www.powertrax.com
Old Apr 15, 2002 | 07:41 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
Most likely it won't. '89 was the x-over year so there's a slight chance it might. But my junkyard findings on late 89 model (May/June) turned up 26 splines.
Linson
Oct 24, 2025 02:00 PM
no green
Jan 9, 2016 09:22 PM
KO1
16
Oct 15, 2015 05:00 PM
Royal_Z
Sep 30, 2015 08:45 PM
