correct fuel pressure reading in the 2.8 and others....
Old Apr 15, 2002 | 04:02 PM
86BIRD-MY FIRST CAR's Avatar
my stock oil pressure guage stays a little below the half way mark, like one line down, is this correct pressure? also is there a way i can measure my tranny oil pressure so i wont havta keep popping the hood open and check the tranny fluid level every time i refill for gas. Also when i accelerate the oil pressure needle rises, when stopping the needle falls, is this normal also?
Thanks........ Abe
Old Apr 15, 2002 | 04:06 PM
Camaro_hunter_d's Avatar
Re: correct fuel pressure reading in the 2.8 and others....
Thanks........ Abe
Fuel pressure should be around 45-49 Oil PSI should be around 35-50 Idle and yes increase as the RPM's increase. Fall when RPM's decrease. Tranny PSI guage, yes doable. But it will not give level out of PSI. You can go to www.digikey.com or www.digi-key.com (hell both go to same place so...)and buy componets to MAKE a level indicator. Expect to spend around 50ish...
If you want I can get a list of parts needed tomarrow from a teacher here. Complete with instructions too...
Old Apr 15, 2002 | 04:20 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Do you have a trans leak?
Old Apr 16, 2002 | 09:51 AM
No tranny leak but it would be nice to scheck the level without opening the hood, and sure camaro hunter ask ur teacher....
Old Apr 16, 2002 | 12:10 PM
mvftw's Avatar
I thought fuel pressure on a 2.8 was 35-40.
Old Apr 16, 2002 | 01:06 PM
SAEspinz80's Avatar
yea, chd...45-49 seems real high for our cars. i thought last time i looked it up they should be around 38-42psi
Old Apr 16, 2002 | 01:32 PM
89camaroRSV6's Avatar
86bird
i think what u really need is a trans temp gauge ....
u dont need to check ressure relaly but trany temp is importnat
Old Apr 16, 2002 | 01:56 PM
I asked my instructor about the level indicator and he is gonna look around for something.
I have a 3.1 and larger injectors and that my PSI reading... Sorry I forgot that...
I asked my instructor about the level indicator and he is gonna try to find something. Basically what your gonna get is something similar to a gas guage though. You may have to drop the pan, to install the float sensor, no promises though.
Old Apr 16, 2002 | 03:21 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Just a FYI, in general: With -only- larger injectors on an otherwise stock fuel delivery system, PSI would not be raised. In fact, with larger injectors on a stock pump, you get higher fuel flow with lowered fuel pressure at WOT.
Old Apr 16, 2002 | 11:21 PM
well my home built A/f gauge works ..for 10 bucks its a good deal...
its not worth it to build a system for level of fluid in tranny...its not really necessary unless u have a leaky tranny...in that case it might be cheaper to fix the tranny than try to build a gauge
Old Apr 17, 2002 | 10:58 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yeah, we should all be checking our fluids every now and then anyway. And don't forget about the power steering fluid!
Old Apr 17, 2002 | 12:18 PM
DId I forget that I also have a dime in the F/P regulator.?... Tom stop trolling...
Old Apr 17, 2002 | 12:20 PM
I did some looking around in my digi key cat, and they have a **** load of stuff in there to make a level indicator if your interested. go to the web site and ask for a catalog.
Old Apr 17, 2002 | 02:33 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You gotta start things up, again, huh? I was posting that info for everyone else! Did I mention you at all? NO! I was trying to avoid "future" questions by other v6 members about increased PSI just by adding higher flow injectors.
And how would giving your adjusted fuel pressure numbers help anyone looking for the correct fuel pressure reading of the 2.8?
92camaroJoe
Jul 29, 2023 07:57 PM
specialized
Jun 18, 2022 09:26 AM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
