Speedometer
Old Apr 26, 2002 | 07:22 PM
85CamaroRulz's Avatar
Speedometer
Why doesn't my speedometer work?? I put a new speedometer cable on and it didn't fix the problem.
Old Apr 27, 2002 | 10:17 AM
CC_HotRod's Avatar
Car: 1984 Camaro
Engine: V6
Transmission: 700 R4
Check the gear in the transmission. On the tailshaft on the drivers side there is a plate that you remove with two bolts and you can look in there at your gears. A gear may be stripped or the clip the holds the gear in place may have brocken.
Old Apr 27, 2002 | 03:08 PM
Belts Squealing, Timing off
yea i had just put another engine in my car, we put a new water pump in and ever since we did that, my belts squeal when you go on the gas.they almost jump up and down. and now my uncle used a timing gun and my timing was anywhere from 18-20, It's supposed to be from 10-12. Email me back or just reply
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
