How fast can my 2.8 go?
Old Apr 29, 2002 | 06:50 PM
trannyman's Avatar
I'm looking to possibly fix my 2.8 up a bit and was wandering what are some of the basics to do to get the car goin faster.
thanks for the input
Old Apr 29, 2002 | 06:53 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Exhaust should be first with a high flow cat. then id do power pullys i noticed a nice difference in power with them and it made my gas milage better i went from 220 miles per tank to over 300 per tank thats city driving. Then get a MSD coil and MSD 6A, Then throw in a chip, Oh a Cold air intake should be first not the exhaust.
Old Apr 29, 2002 | 07:36 PM
V6camaroman's Avatar
try doin some of the mods in my signature. start out with a basic tune up and so on then go to bigger mods
Old Apr 29, 2002 | 07:48 PM
CamaroChick's Avatar
a 2.8 can go absolutely nowhere... argh... atleast it beats a mustang.. wait, my Schwinn does that too...
Old Apr 29, 2002 | 09:12 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
well, you can make a 2.8L go fast, but it's gonna take time and money, both of those are two things that many people aren't willing to spend. You can create horsepower with bolt on modifications, but the big ponies are locked away within the motor. The first thing to do is a major tune up, TomP has a tech article on how to perform this and what all needs to be changed. Then you can think of doing a K&N Filter with Cold Air, next i'd follow with a complete exaust system, (it can be pieced together however, think a Hi-Flow Catalytic Converter, maybe a 2.5 or so In. Intermediate pipe, then follow that up with your choice of muffler, dynomax or flowmaster (both are nice, but those will get your panties in a ruffle if you discuss them to much...everyone's torn between them). After exaust, go with some underdrive pullies, and then onto the ignition. MSD6A/L, MSD Super Coil, and a set of 8.0MM or 8.8MM wires, after all that's done i'd recommend going inside. Go with a double roller timing chain and a crane Compu-cam 2030. That'll improve the engines performance a lot by increasing the ammount of air you can get in and how much exaust can go out that now freeflowing exaust system. Do a set of roller rockers, valve job on the heads, if you're doing a complete rebiuild, do all of this, plus go with a higher compression piston setup, say 10:1 or so. With all of that you'll be moving nice, a set of 3.73 gears outback wouldn't hurt either, to firm up your shifts and make the car feel like it's a haus even if it isnt, think of doing a vette servo, aftermarket boost valve to increase line pressure and a shift kit (transgo or B&M, but many say transgo). Then tkaeh er to the track and see how you run, if all else fails and the previous stuff is done, add a 75hp shot of Nitrous Oxide, maybe 100 shot if you're feeling daring, and then run 13's. eh...maybe 14's . :P
Old Apr 29, 2002 | 09:13 PM
zer0321's Avatar
I hate to be an ****, but go with the 3.4L Swap....
My 3.1L 92 RS Auto is leaps and bounds better than my old 2.8L 84SC 5-speed....I'd even go so far as to say that the 3.1L and definatly the 3.4L V6s (with very few cheap & easy mods) give the 305 V8 TBIs a good run for there money.....
Old Apr 29, 2002 | 10:54 PM
FAST RS's Avatar
I never knew we had a girl on the v6 board. All im ognna say is Hola
Old Apr 29, 2002 | 10:55 PM
FAST RS's Avatar
Ive aways smoked my friends 305 and ive beaten some other 305 camaros
Old Apr 30, 2002 | 09:28 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Doesn't quite sound like she's proud to own a Chevy with six earth shaking cylinders, but hey, whatever.
And how do you want the car to be fast? Top speed? 1/4 mile? 0-60? Fast around sharp turns without slowing down?
Old Apr 30, 2002 | 11:54 AM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
Hey another girl here...Hi all
My 1/4 time this weekend were crap, Total crap. 20.54 (1/4 mile) was the best the car could do. 1987 2.8L MPFI Firebird automatic, 140,000 miles. We checked everything. All the usual suspects are new or read fine (fuel, timing, ignition, new computer, exhaust...etc)
Our suspect is the cam. Its original and we think it is wearing big time. Going to get an oil analysis done, but anyway, nuff excuses.
Well that said. If to have a 2.8 that is running perfect and you have done the following mods, what range should it run in (1/4 mile)?
Cold/Ram air induction
Smoothed and coated exhaust manifolds
2.5 high flow cat
Flowmaster exhaust
MSD coil
ACDelco rapid fire plugs
Taylor 8mm wires
T/B Bypass
EGR blocked off
Beefed suspension
Subframe connectors
17in rims, but the tires are the same overall diameter as stock.
I have done no weight reduction and it has subs in the back.
Old Apr 30, 2002 | 03:45 PM
pontiac's Avatar
20.54 - fresh kickin V6 do better. you've done good work in appearance so i'm sure you'll do the same in performance tuning. keep up the good work.
heavy car with 2.8 wont never fly. with turbo it will hit 350 TPI level, but driveability will be different.
3.4 w/ turbo and 5-speed manual, i'll trade that one to GTA anyday
-P
Old Apr 30, 2002 | 10:04 PM
Yes, it is a girl.. imusually floating around the appearance and detailing boards, though... not building onto a V6... waste of time.. i just gonna go '99 TA... but if anyone can tell me you can get a 2.8 into the 15's, i'd sh*t a brick... me and my mid to low 17's....
Old Apr 30, 2002 | 10:15 PM
WaynesRS's Avatar
2.8s can be quick . I have read about one going 14.70 with alot of mods .I think there is even a thread in the search engine on here .I think thats where I read about the 2.8 that goes 14.70 ! I think its titled something like "2.8 receipe "
Old Apr 30, 2002 | 10:17 PM
WaynesRS's Avatar
Is your anus hurting yet ? Heh ! You should be $hiting a brick by now . :sillylol:
No pun intended but :
maybe ya shouldn't waste your time reading the thread huh ? :sillylol:
by the way , I love your sig , ...the few , the proud , the chevy girls . .......I love seeing girls in camaros !!! Especially hot ones ! Have any pics of you and your camaro ? J/K ..heh
Old May 1, 2002 | 11:47 AM
85f-bird's Avatar
Engine: 2.8L, LS1
Yeh, there was a guy on the board who was from my home town actually was running 15.9, all motor on a 3.1L v6. granted he started with 5 more hp, and about 15lbs/tq extra over the 2.8L, that shouldn't be to hard to accomplish with these little motors. Just takes the two magic words........time and money.
Old May 1, 2002 | 12:15 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Might as well just sell the car and get your Trans Am, then; it ain't gonna happen.
Old May 1, 2002 | 12:31 PM
89camaroRSV6's Avatar
well, im into the 15's...
i posted a thread couple of days back ....
my best Gtech was 15.73...in the 1/4
my mods are in my sig...and time is w/o the spare tire and all the stereo stuff removed..
its not at all hard to get the 2.8 going fast as well...cam,chip,exhaust....
in 3rd gear in my 700r4 i hit a little over 100mph
it doesnt go into 4th @ wot so im having problems keepin it in 4th..but soon im gonna fix that..with the B&M kickdown kit
Old May 1, 2002 | 02:41 PM
Camar_Hunter_c's Avatar
Your 2.8 can go as fast as your pockets are deep.
Old May 1, 2002 | 10:06 PM
sure,i have pics... want one? it's me, my camaro, and my boyfriend with his arms around me...
Old May 1, 2002 | 10:31 PM
WaynesRS's Avatar
Yeah post it !
Old May 2, 2002 | 04:23 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Sounds like my girlfriend! I met her, she had a 3rd gen Camaro, now she's got a 4th gen. "One of these days when I get a website up" I'll post some pics of the car... you guys have seen her before on the 2.8/2.8 swap page.
Old May 2, 2002 | 09:20 PM
JoshDT91's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 2.8L V6
I don't want to know how fast my 2.8 can go. I want to know if it will last long enough till I can afford to get my huge V8 crate engine
Old May 3, 2002 | 11:57 PM
Nah, i no post it.. besides, what crazy person wants to harm themselves looking at an ugly chick? It just shouldnt happen... but hey, now how often do you see a girl under the hood of a camaro, elbows in grease?
Old May 4, 2002 | 10:02 AM
WaynesRS's Avatar
Post it ! I really dont care how ya look ! I just think it'd be neat to see a girl standing by her camaro who loves it and isn't scared of breaking a nail working on it !
Old Jun 30, 2015 | 06:41 PM
beltran89's Avatar
Car: camaro 89 rs
Engine: 2.8l
Transmission: 5 speed
Re: How fast can my 2.8 go?
With a turbo and some slicks it can do 12's
InfernalVortex
Apr 20, 2021 11:31 AM
86maro_252
Oct 10, 2015 06:52 PM
usafirebird
Sep 29, 2015 11:58 PM
spartanreaper
Sep 25, 2015 07:22 PM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
