TTA engine questions
Old May 22, 2002 | 02:09 AM
zer0321's Avatar
TTA
Old May 23, 2002 | 11:57 AM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
i'm at work right now, so i can't really type that long, i'll re-read your thread and give my thoughts and opinions when i get home from work
Old May 23, 2002 | 12:20 PM
Camar_Hunter_c's Avatar
If you can get one togeather for under 3K let me know. And that's JUST THE ENGINE.
Old May 23, 2002 | 01:00 PM
fly89gta's Avatar
Car: 2018 Camaro SS
i got mine damn near complete(just missing little things here and there) for $2300 SHIPPED, and that's a TTA motor not a GN motor
Old May 23, 2002 | 01:02 PM
fly89gta's Avatar
Car: 2018 Camaro SS
just an FYI there is a complete GN engine for sale on gnttype.org in Illinois for 2200 has 85K miles on it..check it out
EDIT: its an 86 u either want an 86 or 87 engine
Old May 23, 2002 | 05:26 PM
Crazy Firebird Kid's Avatar
Car: 84 Trans Am
I'm sure fly89gta will elaborate on this a lot more, but I thought I would give you a few of the things I've learned from reading questions about this swap many times. As I'm sure you know, this is a MUCH more difficult swap then a V8 swap would be. Your current tranny will not fit the 3.8 either, so you will need to get a new tranny. Unless you get a TTA engine, you will need heads off a fwd 3.8 in order to make the engine fit in the engine compartment. All new electronics are needed. Some of the parts you need for the swap are TTA parts that are no longer available, and are VERY hard to find. As I said fly89gta will go into further detail, but this is a difficult swap but well worth it when your done I hope to do the swap myself sometime WAAYY down the road.
Edit: Oh yea, I forgot to mention www.turbobuick.com There are a few guys there who have done the swap. Check it out.
Old May 23, 2002 | 05:51 PM
zer0321's Avatar
okay
Old May 23, 2002 | 05:58 PM
fly89gta's Avatar
Car: 2018 Camaro SS
ok, let me clear up a few things
you DO NOT have to get a new trans for the sake of bolting it up to a buick 3.8, i would however get a new one for the sake of strength. TCI makes an adapter plate that allows a chevy bolt pattern tranny(ex 700r4 to bolt to a BOP block
also a turbo 3.8 with GN heads WILL fit in the engine compartment fine provided you don't have AC, which you don't so we're good there.
As far as the swap goes its not hard..would've taken about 2-3 days to rip a L98 out and put the TTA motor in but there were a few little stupid things missing, it took about 4 days.
the one thing you WILL have to get regardless of if its a GN or TTA motor is a TTA wiring harness, you could try to piece the GN harness with yours but its BIG TIME PITA.
Motor mounts have been a hot debate lately. You CAN use the GN motor mounts but the engine sits up a bit higher, i have TTA mounts...a buddy of mine used GN mounts on his GTA and the engine does sit a bit higher, i don't know if there are clearance issues since he has a 3'' cowl hood.
I'd upgrade the fuel pump while you're at it, the fuel lines and all should be fine.
Like i said its best to get a whole complete engine, the ECM's are cheap if u can't get one with the engine..the TTA harness is a killer, bout 375-500 bucks
I'm sure i'm forgetting little things here and there so if u think of specifics feel free to ask
i'll do the best i can.
BTW i'm VERY happy with the swap, though i kinda blew up my tranny peopl may say bah its not a V8..but whatever, i'm gonna be running better times and be WAY more streetable then they are
Old May 23, 2002 | 06:00 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Originally posted by zer0321
okay from I keep getting two answers from people
some say I need TTA heads to get it to fit, and others say I can just use the GN ones if I don't want A/C (what is the price difference?) or am I talking about two completly different things?
and if you guys are right (which is usually the case) the prices aren't nearly as awful as I would have thought.
the people that insist GN headed turbo 3.8's won't fit in a fbody engine bay tell them to talk to someone i know that has a Iroc vert with a GN headed 3.8.
Old May 23, 2002 | 06:23 PM
Car: 84 Trans Am
OK, I proved my ignorance with the heads part, I guess without AC they will fit, my bad. Fly89gta, did you notice he currently has a 3.1? I'm 99.9% sure that the 3.1 700r4 wouldn't bolt up, the V8 700r4 yes, but I don't think so with the 3.1 tranny. Of course I could be proving my ignorance again :lala:
Old May 23, 2002 | 06:27 PM
zer0321's Avatar
I have a SS Hood....do you think clearance would be still be problem with it w/ the GN mounts?
So what I need for the setup is:
Complete GN Turbo 3.8L V6 Engine (looks like about $2500 when I shop around, how much power are these rated at?)
Buick 200R4 Automatic Tranny ($350)
New Motor Mounts (GN?) ($?)
TTA Wiring Harness (how much would it cost to have the GN one "pieced" together with mine?)
what about my v6 radiator and gauges, will they work or do I need to get replacements for them too? can anyone think of anything else?
I was thinking I should probably get some subframe connectors before the swap....
Old May 23, 2002 | 06:32 PM
fly89gta's Avatar
Car: 2018 Camaro SS
not sure about the V6 700r4 but i wouldn't use it PERIOD
AS far as the 200-4r don't forget you'll have to get a new crossmember and torque arm(Steve Spohn has them both for $399) and you'll hve to get a driveshaft.
Trust me don't try to piece the GN harness, its more trouble than what it's worth.
I didn't have any problems with my gauges except the tach, it didn't work so i got myself a 5'' tach
the Rad should work..and i'd DEFINATELY get subframes
As for labor costs at a shop i really don't know, a lot of shops probably wouldn't want to touch it, and i wouldn't trust anyone that doesn't know turbo buicks
As far as power...hmmm well they're kinda underrated from the factory..i'd put it around 260 HP and over 300 ft lbs of torque, but its SOOOOOOOOOOOOOOOOOO EASY to mod these things..is just sick.
Old May 23, 2002 | 06:45 PM
zer0321's Avatar
Thanks for the help fly89gta
Old May 23, 2002 | 07:23 PM
fly89gta's Avatar
Car: 2018 Camaro SS
if u stick with the 700r4 you won't need to swap out all that stuff
as for the 700r4 vs. 2004r MOST buick guys will tell u not to use the 700. I've read a few people having good luck using the 700r4, i'll eventually convert to a 2004r when i have the cash
the problem with the 7004r is the steep first gear, sure it's great for a N/A car but by the time the turbo spools up u have to shift into 2nd...the 200r4 has a slightly better gear spread suited for a turbo motor...but i'm gonna run the 700r4 and see what i can get out of it
best thing to do is this...DO LOTS OF READING....i spent time on af few sites just reading...soaking in the tech stuff and opinions by the guys that know what they're talking about
www.turbobuick.com
www.turbobuicks.com
www.gnttype.org
start reading!! LOL
Old May 23, 2002 | 11:00 PM
Setzer's Avatar
I cant give any advice about the swap, but I will say this. To my knowledge, you cant use your 3.1 700r4 because it is a 60* motor. The 3.8 motor is a 90* motor. You would have to get another tranny.
~Josh~
Old May 23, 2002 | 11:54 PM
zer0321's Avatar
I pretty well figured that if I am gonna do the swap, I might as well go all the way and use the 200r4, though I really need to get money before I do anything...
Old May 24, 2002 | 07:12 AM
fly89gta's Avatar
Car: 2018 Camaro SS
~Josh~
yeah you're right, but like i said i wouldn't use it regardless if it would work or not...that poor tranny wouldn't last past 2 gear
Old May 24, 2002 | 12:31 PM
Ovrclck350's Avatar
Fly...he's got a V6 tach. The tach should work fine, but I'd go ahead and get another just in case. What would be great is if you could score a TTA gague setup with the inlayed boost gauge.
Old May 24, 2002 | 12:43 PM
fly89gta's Avatar
Car: 2018 Camaro SS
someone i know put a V6 tach in and that didn't work either...i was gonna go ahead and swap tachs but after i heard his didn't work i didn't bother, just put a 5'' tach in
as far as the TTA cluster be prepared to spend BIG bucks...also the oil pressure gauge is 80 PSI, but i think all V6's got them..TTA gauges are expensive
Old May 24, 2002 | 01:01 PM
Ovrclck350's Avatar
Odd, I heard the V6 tack will work. Oh well, just a thought.
Old May 24, 2002 | 01:04 PM
fly89gta's Avatar
Car: 2018 Camaro SS
yeah i heard it will work too, but it didn't..ah well maybe it was a bad tach
Old May 24, 2002 | 01:40 PM
Car: 84 Trans Am
http://www.turbobuick.com/messagebd/
Just found that, thought you might be interested..........about 3/4 or the way down a guy is selling his TTA wiring harness.
hmm, ok, i guess I can't just copy and paste URLs off that sight. Its under Turbo Trans Am tech, then "Wanting to use a gn engine in camaro" Then it's 3/4 of the way down.
Old May 25, 2002 | 04:17 PM
zer0321's Avatar
Old May 25, 2002 | 06:19 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
grr.....This is so frusterating....I wish I had money....
I don't really want to put a new Tach in, I would like it to look as stock (and done as cheaply) as possible....sucks *** being 17, ya can't get any good jobs until your 18...
Being 17 sucks eh. I got my car when I was 17. Now I am 19, well same job better pay a hell of a lot more bills, school etc.
Not to preach at you. But if you think as soon as you turn 18, or when your done college your going to have no bills, no mortgage a new car, and all your money to yourself you have something coming to you. Moddifying your car will always be on the bck burner. But someday when you can do it you will really enjoy it.
Trust me I should have modded my car before school. Or did something. All I know is 8% hike in school fees means good bye toys (firebird).
This is one interesting post. Although it does not seem like anything I will ever do, theres always lots to learn.
Old May 26, 2002 | 01:50 AM
zer0321's Avatar
Old May 28, 2002 | 12:08 AM
1BADDAM's Avatar
Car: 89 TA
Engine: 3.8 V6
Transmission: 2004R
Need a pass. side header?
I'm selling the pass. side header off a TTA, this is the discontinued one. Much needed for a 3rd gen LC2 swap
if you wanna keep the a/c. Custom headers are pricey.
.....$300
Old May 28, 2002 | 05:40 PM
zer0321's Avatar
Old May 28, 2002 | 06:03 PM
Ovrclck350's Avatar
Re: Need a pass. side header?
.....$300
Funny...I can get a full set of custom headers for $250.
Old May 28, 2002 | 10:10 PM
mechanicalmehem's Avatar
Ovrclck350
Ovrclck350
I am planning on building a setup for a 2nd series 3800 but am planning on doing a TTA essentially, I realize that a series 2 head exhaust port would be different but if I could get you trace(paper and pencil, rub surface) do you think you could get me a set built that would be close enough to match? Just PM or respond or whatever, thanks.
Justin
Old May 29, 2002 | 07:56 AM
1BADDAM's Avatar
Car: 89 TA
Engine: 3.8 V6
Transmission: 2004R
Re: Re: Need a pass. side header?
...and I can get a set BFG Drag Radials, m&b for a $100, just depends who you know.
Old May 29, 2002 | 09:27 AM
SheckyZ28's Avatar
You guys are talking about clearance issues with the GN motor mounts. If I end up using them in my 3.8 from a '89 TTA swap to my '92 Camaro how bad of a clearance problem will I be looking at?
<br>
And no, I didnt get the right motor mounts from the guy who sold me the engine. He gave me grand national ones. So any help getting those to work, OR what Id rather do if find the parts I do need to do this right, would be nice.
Old May 29, 2002 | 09:54 AM
fly89gta's Avatar
Car: 2018 Camaro SS
i don't know for a fact if there will be a clearance issue....the motor WILL sit up higher with the GN mounts, but like i said my buddy who used GN mounts has a 3'' cowl hood so i don't know if it would fit the stock hood
Old May 29, 2002 | 10:19 AM
Ovrclck350's Avatar
Re: Ovrclck350
Originally posted by mechanicalmehem
Ovrclck350
Justin
I'm not sure, I'd have to talk to my guy. You'd have to leave your car with him though for him to make them.
84z96L31vortec
Aug 20, 2017 12:16 AM
lee01
Apr 9, 2016 01:56 PM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
