Blower :)
Old Jul 7, 2002 | 09:00 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Blower :)
I was looking at random stuff on the net and found a blower for a 2.8
HEre is the companys main site the first link is a picture of the blower with some information on it.
http://614streets.com/Fageol.html
http://fageolsuperchargers.com/
Old Jul 7, 2002 | 09:11 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
cool, but you'll have to convert to carb or TBI first
Old Jul 7, 2002 | 09:31 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
sweet, custom fuel rails, intake adaptor, good to go
or
get an 82-84 car. I know where an 84 SE 6cylinder is right now too!
Old Jul 7, 2002 | 09:33 PM
hmmmmm...i think that could work too
Old Jul 7, 2002 | 11:33 PM
KED85's Avatar
I almost bought that guys kit back in the early 90's for my S-10 Blazer.
For $2500..........
I can insert a V-8 into my Blazer for 1/2 that much & get more power!
I'm inserting a 3.4 long block with 50K miles on it, rebuilt tranny and "new" used rear axle & gasket & I still come up way less than spending $2500 on just a supercharger for a worn engine.
He's in El Cajon, right?
I saw one of those at a swap meet for like $500.
I was gonna give the guy $50 and help him take it off his hands.
I could put that on the 3.4 I've got in my Blazer, tho!
Anyone want to buy it for me!
Old Jul 8, 2002 | 09:04 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
it only gives 5 lbs of boost at 5000rpm. Thats kinda lame.
now if it had 5lbs at 2500-3000, im am getting excited.
it is real neat and different.
Old Jul 8, 2002 | 09:56 PM
Engine: 5.7 / 7.4
put a smaller puley on it
Old Jul 8, 2002 | 10:40 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
sure that is simple but would it last very long like that?
spinning 2-3 time faster than designed for could cause havoc on the teflon seals.
I believe the racing ones do not but the street blowers have teflon seals on the screws.
how long do they last even when its a street blower?
I fear with the same ammount of cash a turbo would be better, if you spend the same ammount for a good turbo 20+ bo0st. not as neat as a blower sticking out of the hood though.
but it would suck having a blower n get wooped on, with a turbo they cant see it.
Old Jul 8, 2002 | 11:04 PM
Engine: 5.7 / 7.4
we caint go with that much boost on stock motor ( 9.5:1 or so)
maybe on the bonnie's motor (7.6:1 from factory, but cast pistons)
Old Jul 9, 2002 | 12:52 PM
GhostRider84's Avatar
Theoretical question - on the 60* engines 3.4 = longest stroke - 2.8 the shortest. Could you put, say, a 3.1 crank in a 3.4 block to lower the compression ratio & run a massive boost?
Old Jul 9, 2002 | 08:49 PM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
3.1 crank 3.4 crank are the same, the piston pins are set higher for the compression increase. Rods are the same too.
codeysabatini
Nov 10, 2015 04:07 PM
86IROC112
Sep 28, 2015 08:17 PM
buckeyecelt
Sep 24, 2015 05:50 AM
soarestransam
Sep 1, 2015 04:00 PM
mhatfield 14
Aug 15, 2015 10:47 AM
