Questions on adding IROC sway bars
Old Jul 13, 2002 | 10:52 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
I found someone that will sell me a set of front and rear IROC sway bars as well as the wonderbar. Can I use the existing endlinks on my car or should I (and where) go get new ones? I already plan to get new bushings. Are there any kits out there that include all new brackets and all that?
Also, what are some solutions to the lower radiator hose hitting the thicker sway bar?
TIA
Old Jul 13, 2002 | 11:04 AM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
I do not know all that much about suspension but I would get the poly Urethane kit with all the bushings and ends from Summit its like $129. I am sure you would not regret getting it.
Old Jul 13, 2002 | 01:13 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
I re-used the end-links and it works fine. I didn't feel like buying any bushings. Oh, and the radiator hose isn't affected by the sway bar........but the wonderbar might. When I bought my sway bars I didn't buy the wonderbar so I don't remember if it will interfere.
Old Jul 13, 2002 | 01:28 PM
Xenodrgn's Avatar
Make sure you have the rear brackets for the sway bar if you car wasn't optioned for one... also, I got my entire end link set with bushings for 15 dollars at Pep-Boys, they are polygraphite bushings. I have been very happy with my now much tighter rear-end (my car was not optioned with a rear sway.)
Old Jul 13, 2002 | 10:39 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
What's the difference between the $130 kit from Summit and the $15 dollar one from Pep Boys?
Oh and don't all camaros 86 and up have rear sway bars?
Old Jul 15, 2002 | 02:24 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Wow, what $130 kit? End links from Summit, part #ENS-9-8117R (r for red) or ENS-9-8117G (g for graphite=black), $13.99! Were you looking at the full Hyperflex suspension rebuild kit? http://store.summitracing.com/partdetail.asp?part=5374',650,505,'ENS98117R'
Old Jul 16, 2002 | 06:11 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Whatever kit Joe was talking about, I was asking what's the difference between that and the $15 one from Pep Boys.
Oh wait. I guess he's talking about a suspension rebuild kit, not just end links.
Old Jul 16, 2002 | 12:11 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Tom, that's the part number for the the correct end links and bushings for use with IROC front sway bars? What about rear?
Old Jul 16, 2002 | 01:50 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Same for rear; you measure the sleeve length. That's the piece of metal in the center of the end link, between the bar and the body mount. Measure it between the washers. That part # is for a 2 5/8" sleeve length. You can order different lengths to tune the suspension, but that part # is off the http://www.energysuspension.com online parts listing. It doesn't matter which bar you're putting on, if it's a stock bar from a v6 or trans am or iroc or an '82 z28, they all use the same length end-link. You should search the Suspension/Chassis/Brakes forum for more info on "sleeve length".
And sorry, I didn't even see Joe_L's message! I saw you asking about a $130 kit and thought "no! Don't spend that!" and didn't read any of the other messages. My apologies!
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
redmaroz
Aug 16, 2015 11:40 PM
