Ignition modules & igntion boxes.....
Old Jul 15, 2002 | 10:41 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
I'm planning on getting 2 systems, 1 for the bonnie, 1 for the bird. bonnie will get the Mallory HyFireIV-A & pertronix hei coil. Bird will get either the MSD 6A & later the BTM for the turbo or the 6BTM all-in-one, if I can swing it. Can I keep the stock ignition modules for these since I'm going for the ignition boxes, or will after market ignition modules and aftermarket boxes be the ticket?
Old Jul 15, 2002 | 12:30 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Not sure about the bonneville (year, etc?) but for the f-body you could keep the stock ignition module. The MSD box connects to our remote HEI ignitions just like you're replacing a coil. On older HEI ignitions with the coil in the cap and the 4-pin ignition module, the MSD replaces the module. But for our cars, just think of the MSD box as a big coil... because that's all the car sees it as.
Old Jul 15, 2002 | 01:05 PM
Engine: 5.7 / 7.4
thanks, the boat is a 76 w/coil in cap. The manufacturers, at least in their adds never really cover this. :hail:
Old Jul 16, 2002 | 10:38 PM
WaynesRS's Avatar
Project , do you know that if you buy the Mallary system from Summit right now you get a free set of Mallary plugwires with it ?
Old Jul 16, 2002 | 11:19 PM
KED85's Avatar
I do know that Accel makes a remote coil set up for the HEI in cap GM distb.
Which is kinda good.
The coil gets hot & it's heavy & wears/weighs down on the innards spinning round.
In theory this is a good idea to remove the heat & the excess weight.
Why not install a small cap rotor (if available) in the Bonnie?
Old Jul 17, 2002 | 10:10 AM
Engine: 5.7 / 7.4
coil in cap will be just fine, & cheaper too
is the mallory promo just in the summit catalog, it's not on the web sight.
TomP is right, downloaded the instructions for the MSD 6 series boxes, on the gm 4-pin modules, they are removed & replaced w/harness adapter. 5 & 7 pin modules are kept in place. Haven't really looked at the birds coil, is it 1 or 2 connecter? they have diagrams for both. Also won some accel wires on e-bay for $18.49
Old Jul 17, 2002 | 10:57 AM
KED85's Avatar
I always agree with modding what ya got, too.
I just recall that downside to the GM HEI set ups.
Old Jul 17, 2002 | 11:34 AM
Engine: 5.7 / 7.4
only problem I ever had w/HEI was that rotor breaking in half on the T/A
Old Jul 17, 2002 | 12:42 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The 85-up 2.8/3.1 coils are remote, 2-connector. I think the V8's went to a remote coil HEI in '87? Not sure of the year with the V8's. But you won't find a 3rd gen with a single connector remote HEI coil.
InfernalVortex
Apr 20, 2021 11:31 AM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
dusterbd
Sep 29, 2015 08:40 AM
tattmann
Sep 27, 2015 05:20 PM
