Ha, Ha! Swapping front sway bars? Don't do what I did!
Old Jul 17, 2002 | 01:01 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I never did a re-torque on my front sway bar mounting brackets!! I dove under the car yesterday to do a lube job, and nearly scratched my eye out- the driver's side sway bar mounting bracket (going to the frame) was bent down!! I somehow lost the rear bolt, and as I was driving, the bar must've been bending- and bent the sway bar mount completely flat, so it was pointing straight down!
So check the torque of those bolts! By the way, the bolt is a metric 10x30mm, coarse thread. $1.20 each in the hanging "bubble pack" at Pep Boys. And I thought my car's understeer was caused by the crack in my bad rear 1/4 panel. Oops.
Old Jul 17, 2002 | 02:42 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
OO damn. On my s10 I had the end links come out going down the interstate. I noticed a drastic change then. So when I find some and swap them out, I will make sure I tighten the **** outta them
Old Jul 17, 2002 | 03:55 PM
WaynesRS's Avatar
Oh $hit , you guys dont be telling me this ! heh . I have the same tie-rods and frontend on my car . CAR HAS 189K ON IT !
Old Jul 18, 2002 | 06:12 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
<----- Grabs torque wrench for installing IROC sway bars and wonderbra.
Oops I mean bar.
Old Jul 18, 2002 | 07:07 AM
Dale's Avatar
Engine: 350 S-TPI
Hey mike, did you notice a difference installing that wonderbra on your car?? I noticed one on ebay for 46 bux, and I plan on going to a junk yard on saturday. I was thinking of looking for one. Where is it located at under the car??
Old Jul 18, 2002 | 11:29 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
I didn't install them yet, I'm picking them up on Sunday. Another week or 2 and they should be on the car.
Old Jul 18, 2002 | 11:56 AM
Dale's Avatar
Engine: 350 S-TPI
ok, let me know how it goes.
Old Jul 18, 2002 | 02:23 PM
Camar_Hunter_c's Avatar
I have wonder bar, Iroc sways, and the strut tower brace. Out of those the 'Roc sway really tightened the suspension up. The Wonder bar did not do alot. The Strut bar, yes made a differnce WITH the wonderbar, as it completely boxed the front end then. I now squeel tires around turns that I did not before so I know the front is tight as hell.
Old Jul 18, 2002 | 03:04 PM
Dale's Avatar
Engine: 350 S-TPI
So if I find a wonderbar, along with the sways, jack it. But if not, its not a big deal? I heard them tower braces are not a good idea for daily drivers (or thus on euro trash). I gonna go with the sway bars first, then maybe that. I'm still currently working on the engine, so it would just get in my way for now.
Old Jul 18, 2002 | 05:12 PM
the first thing I did was get sway bars. They made a HUGE difference. I then put on the "Wonder Bar", well one wonders what is does. It did not do anything special for me. I then put on that Jamex strut bar, and 'Oh holly hell BatMan, the front is tighter then a virgin nun! Well worth the $30 bucks and the month wait.
Old Jul 18, 2002 | 09:15 PM
Dale's Avatar
Engine: 350 S-TPI
I been with ones that tight, I pass . Since Its for my wife, I will prob just get the sway bars for now, and see if she likes the ride and turning. If she wants better, it leaves me space for improvement. Thanks for the info!!! :hail:
Old Jul 20, 2002 | 10:04 AM
Dale's Avatar
Engine: 350 S-TPI
Just returned from the salvage yard, all the f-bodys that still had sway bars they were 1.375 in dia., and most had rear sways that I would say were .75-1 in in dia (visually looking). These are not what I'm neededing correct?? What size am I needing?? Thanks
Old Jul 20, 2002 | 10:24 AM
the ones that have the "about 1"" rear sway, GET 'EM BOTH. They are about 1.25" front and 1" rear. Its funny if you compare the new rear to the old V6 front the new rear is almost thicker!.
Old Jul 20, 2002 | 11:37 AM
stuart69427's Avatar
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
you guys are getting me anxious to put my WS6 sway bars on. Which are 36mm Hollow Front and 24mm Solid Rear. If you compare the difference in size, its just amazing how "BIG" six milimeters difference really is (I have my original 30mm front/18mm rear on my car).
I am not good with the loosy standard system (and i am full blooded, born on american soil boy) and don't know what these sizes are in standard. the metric system is so much better, no fractions or decimals necessary...
Old Jul 22, 2002 | 01:07 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I don't like to bring my calipers to the junkyard... 1, they can get messed up; and 2, they wrecking yard owners might think I'm a rich boy or something, so I use an open-ended wrench and a piece of paper. I use a ruler to draw a 36mm line on a piece of paper. Then I tighten down an open-ended wrench on the CENTER of my current sway bar, and mark the jaws on the paper. Then when I'm at the yard, if my wrench won't fit over a junkyard f-bodies' front sway bar, I know that car's bar is bigger than mine.
Oh I guess you could also bring a small metric ruler into the yard along with the adjustable wrench...
Old Jul 22, 2002 | 01:37 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Oh yeah, and Wayne, it's not a hard job to replace the pieces. Tie rods are easy, center link is easy. Idler arm requires some extra effort (I hear we need to make marks on the frame to install the new idler in the same place so as not to throw the alignment far off.) Replacing the lower control arm bushings and balljoints requires more work in the way of disassembly. I tell ya though, back in '95 when my center link and idler arm was replaced, it made for a HELL of an improvement in handling! That's why i want to replace it all again.
And as an update to my bolt-fell-out-and-bracket-bent problem, that bracket wouldn't go back into the original shape. I think it might if I spent hours on it, but I'm not going to. I'll grab one from a junkyard.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
bellez77
Sep 5, 2015 08:39 PM
