What does it mean when you see sparks under the hood?
Old Aug 1, 2002 | 10:05 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Got home tonight, and figured I'd lift up the hood. I saw some small blue sparks I think where the boot goes on the rear passenger side plug. Any ideas what causes, and solutions? Would this be the cause of my crappy gas mileage, ,or is that more from my leaking exhaust manifold?
Old Aug 1, 2002 | 10:10 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
problem: bad plug wires
solution: new wire plugs
and yes, crappy milage & makes engine run rough.
Old Aug 1, 2002 | 10:12 PM
Camar_Hunter_c's Avatar
You mean plug wires? J/K But yeah.
Old Aug 1, 2002 | 10:14 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Wires were just put on in April, MSD 8mm.
Old Aug 1, 2002 | 10:20 PM
Engine: 5.7 / 7.4
allright , plug wires
don't they come with some warranty or something? maybe see about heat boots for them. I got some from a recent car club event when they swapped on some taylor wires.
Old Aug 1, 2002 | 10:23 PM
I just have some ford V8 Accell's on. I just trimmed the boots a little. The black part 1/4" and the orange 3/8" work fine, no radio interferrance, not melting(thats a good thing) there High Heat so.... were 25 at Crap Zone.
Old Aug 1, 2002 | 10:26 PM
WaynesRS's Avatar
Let me guess , your two plugs by your EGR valve are shot to hell ?
Wanna fix this problem and not have to change those plugwires all the time ?
Taylor heat sleeves from Summit
E-mail or call summit up and tell them you need two of there taylor heat sleeves . Or if you wanna put heat sleeves on all of the boots , just get the eight pack of heat sleeves . I use to have to changed 2 of my plugwires , the 1 and 3 one between the Egr every 2 months , I got hose sleeve protectors and I've had them on there for almost 6 months now ! ....Those suckers work !!!
Old Aug 1, 2002 | 10:29 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
From what I could tell its only the one at the rear. I'll look into the heat shields.
Old Aug 1, 2002 | 11:57 PM
AFrikinGoodTime's Avatar
Years ago I went through two #3cylinder plug wires in 6 months because of the heat from the EGR. I've run thermal boot sleeves on my Taylors for aprox 6 years now and my wires are still perfect.
Old Aug 2, 2002 | 12:09 AM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
LOL the stock heat shields make it worse, use ACCEL high temp wires from summit, sometimes what your seeing is tracking, put silocone grease in the boots, also be sure to relocate your coil, it gets cooked by the EGR. The glow around the Coil is normal, how do I know? well I have 6 coils that I tryed all do it from the minute you put them on.
Old Aug 2, 2002 | 01:01 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Re: What does it mean when you see sparks under the hood?
You saw actual sparks, or a blue glow? A blue glow at the base of the plug, where it goes into the head, is normal; can't get rid of it.
Old Aug 2, 2002 | 01:33 PM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
Could be that the wire is not fully on the plug
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
MM2Robinson
Oct 1, 2017 09:16 AM
camarohelp
Sep 22, 2015 03:19 PM
Jlanz55
Sep 9, 2015 09:09 AM
