Jumpy Tach
Old Aug 26, 2002 | 07:24 PM
HurtHorseZ28's Avatar
Jumpy Tach
Ok, here's the deal. Every time I stop while in drive, my tach is jumpy and the car has a bit of a rough idle. Sounds like it wants to stall, but hasn't yet. Then as soon as I am on the gas, things seem kosher, but it still jumps a little.
What's this sound like? Thanks!
Old Aug 27, 2002 | 11:43 AM
Camar_Hunter_c's Avatar
Alternator/batt is going out. Trust me. I have a remote mount batt and a couple days ago the power wire came off. And the tach was all over the place. Ihave a high output alt so the idle/running was fine.
Old Aug 27, 2002 | 03:06 PM
Ahhh, it is most likely the crappy battery that is in there now that leaks acid. I've been meaning to get a new one anyway. Thanks!:hail:
Old Aug 27, 2002 | 04:30 PM
squirrelybird's Avatar
is that really the problem? because that sounds exactly like what mine is doing, but i know my battery and alternator are fine. i dont think it is like your prob HUNTER C, because ours is not just the tach jumping inaccuratley...the rpms are actually jumping
Old Aug 27, 2002 | 07:20 PM
Well, mine does seem to be more of just a tach problem and not an RPM problem. Because other than the crappy idle at a stop, it seems to run ok when on the gas, just the tach jumps a little, but I don't feel the RPM's changing.
Old Aug 27, 2002 | 07:24 PM
funstick's Avatar
sounds like a bad igntion module. if the ignition moduel is bad i would replace teh coil module and pickup.
Old Aug 27, 2002 | 08:02 PM
Well, I replaced the battery and checked out the alternator. Battery is good, and the alternator puts out 14.4 volts. So it's not that.
So ignition module eh? Always something. I'll try to narrow it down before I jump into anything.
Old Aug 27, 2002 | 08:58 PM
No I know that the tach was doing, and what was the prob. The tach was going side to side at a steady RPM Gas peddle. And it was the dissconnected batt wire, as as soon as it went back on the tach was fine.....
Old Aug 27, 2002 | 08:59 PM
The module either works or doesn't. no in between. It is what feeds the ignition to run the car.
Old Aug 27, 2002 | 10:14 PM
Ohhh, you mean the batt wire that goes to the distributor? I'll have to take a look there. It's just driving me nuts.
Old Aug 27, 2002 | 11:18 PM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
Your problem isn't the module, but the PICK UP COIL in the distributor. The jumping in the tach is the coil going to ground and not signaling the module which runs your tach and main coil. Comman problem on Camaros and the easyiest to fix but you have to take apart the whole distributor to slide off the old one and slide on the new one. Don't delay because if your having a ruff idle it's getting bad, the jumpy tach is just the begining. When the pick up coil finally goes bad the car won't run.
$750 L98
Feb 1, 2025 02:25 PM
86maro_252
Oct 10, 2015 06:52 PM
Eric-86sc
Sep 28, 2015 11:37 AM
RedLeader289
Sep 23, 2015 06:50 AM
TrevinE
Sep 14, 2015 03:20 PM
