Lets get some numbers...
Old Sep 1, 2002 | 09:37 PM
Akshay's Avatar
How many miles did your Camaro have before you needed a new engine and/or transmission?
Akshay
89 RS w/ orig. eng (91K miles) and tranny
Old Sep 1, 2002 | 10:10 PM
1986CamaroSC's Avatar
Car: 1986 Camaro SC
i'm at 80,000mi,(128,000km) and still running strong..
Old Sep 2, 2002 | 01:44 AM
Ragnarok_Tyr's Avatar
120,000 miles and still running like a champeen!
Old Sep 2, 2002 | 05:07 AM
Camaro_1986_19's Avatar
68,000 miles thanks to my sorry *** on overheating the engine and keep driving!! My tranny still shifts great
Old Sep 3, 2002 | 11:47 AM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
My 85 -- 142,000 original
My 83 -- 154,000 (rod knock) now at 165,000
My 86 -- 180,000 (rod knock) new motor in but not tagged yet
Old Sep 3, 2002 | 11:58 AM
Brian K's Avatar
120K tranny leaked out of every spot it could.
160K the original timing chain went
That is the only major things on my car. My compression test shocked them because I am susposedly in great shape. I do not burn any oil and ran synthetic until the rear meain seal went and I have yet ot fix that, but recently I was in an accident so who knows what is going to happen now...
Also, I run 16.01 with this tired engine and my mods.. Imagine a fresh engine or if I get it fixed I gaurantee I will bust into the mid 15's with my headers and new timming chain...
Who knows, if they total it a 1994 or 1995 Z28 will replace it. White, T-Tops or Red with T-Tops...
I rahter they fix my car... I have found fiberglas front 1/4's and a fiberglass hood. That should shave some weight..
Old Sep 3, 2002 | 02:16 PM
89camaroRSV6's Avatar
that fiberglass should push u into teh 15's for sure
our hood weighs a lot!!!!!!!!!!!!
what are ur mods brian?
Old Sep 3, 2002 | 03:14 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Well, I"m still on the original motor at 238,000 miles
I'm on my third trans (original died in '97, first rebuild died in '98, current rebuild is ready to die)... but ya know, I don't think I ever wrote down the mileage of the car when they died. I'll see if I can find the Lee Myles receipt for that $1300=1.5year transmission (the first rebuild).
Old Sep 3, 2002 | 04:03 PM
Berlyn0963's Avatar
Car: 91 Camaro RS
Engine: GM PP crate 350
Axle/Gears: 3:42 spooled 10 bolt
my car itself has 209,000
its at the dealer now for installation of a new GM TH700R4 tranny & should be out & ready by sept 5th
the engine is between 75 and 90,000 and i got a new rear end and new U-Joints
so basically i got a whole new drive train
time for a tune up i guess
Old Sep 3, 2002 | 08:27 PM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
rod knock at 95K. ..goin' strong now on 130K
Old Sep 5, 2002 | 03:40 AM
rezinn's Avatar
Trans was rebuilt at 113k, new engine at 133k. The engine could have lasted, but it was burning a lot of oil.
Old Sep 5, 2002 | 06:51 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
164k on the engine, still going strong. Just had the tranny rebuilt at 164k.
Old Sep 5, 2002 | 10:36 AM
pontiacguy1's Avatar
The 1992 3.1 Liter is still running strong at 166K miles, even after using the nitrous since 1996. I haven't had any tranny problems either, except some minor slipping on the 1-2 shift while using nitrous. Car uses no oil and still gets nearly 30 MPG on the interstate.
Old Sep 5, 2002 | 12:17 PM
Akshay's Avatar
Wow, amazing numbers guys!!!
Akshay
drathaar907
Apr 30, 2015 01:44 PM
Bohemian
Convertibles
Jun 1, 2014 10:57 PM
tekn0pumpa
Jan 25, 2014 08:23 PM
mwlockhart
Nov 11, 2013 10:18 AM
kane91z
Jun 29, 2001 03:11 PM
