Idea... lower the front of you 6 with springs...
Old Sep 26, 2002 | 06:34 PM
Xenodrgn's Avatar
the rear end carries as much weight as 8cyl cars... 8cyl springs should work to lower the rear of the car... but what if you were to buy 4 banger springs and put them in the front of the car?
Are the springs different?
{EDIT} edited for clarity.
Old Sep 26, 2002 | 07:54 PM
camaro89dude's Avatar
I'd think V8 springs would raise the front of the car, since they are supposed to be holding up more weight. Could be wrong though. But I would think either that or no difference at all, definately not lowering.
There are people on here who cut their springs, or ordered Eibach springs and cut them.
Old Sep 27, 2002 | 10:27 AM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
Originally posted by camaro89dude
There are people on here who cut their springs.
Isn't that a no-no...?
Old Sep 27, 2002 | 10:37 AM
Some say yes, some say no, it all depends on the technique you use on them and then how you use the springs.
Old Sep 27, 2002 | 11:20 AM
Xenodrgn's Avatar
The weight on the rear of our cars should be the same... because all the weight difference with a different engine is in the front... so V8 lowering springs would probably work, or yes at least have no effect except for the stiffer ride...
I4 springs in the front though... those little motors didn't weigh crap, and I'll bet our 6's would push them down...
Now does anyone work at autozone or some crap like that around here that can look up numbers?
Old Sep 27, 2002 | 11:40 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
like I said in a post many moons ago, get the 6cyl springs for the manual w/o a/c. these are a good 6-8 inches shorter than a set for an 6cyl auto w/ a/c.
Old Sep 27, 2002 | 12:12 PM
Xenodrgn's Avatar
Yeah, that'll work too!
Hah, didn't even think of that...
I've got 8 cylinders to push the front end of my car down though, this post was just to help you die-hard 6'ers.
Old Sep 27, 2002 | 04:04 PM
DAN_92RS's Avatar
Car: 92 camaro RS
Engine: 3.1L v6
i think the stock springs r just as good dont want to lower the car any more than it is already got paint chipin in my front end.
Old Sep 27, 2002 | 07:45 PM
Ovrclck350's Avatar
I have SLP V8 Take off's in the back...not bad for $20 practically brand new.
Old Sep 27, 2002 | 09:27 PM
Engine: 5.7 / 7.4
when I put the 14"rims back on the car, I'll push it out & take a pic. you tell me how the stance looks. & remember, the front springs allready have 1 coil off of them.
Old Sep 28, 2002 | 07:47 AM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
I have a suggestion.
I was looking through one of my summit catalogues, and found a package that came with drop spindals, and then you could buy lowering springs for the back.
Just think no worries about car looking weird, cause the front has no V-8 lowering springs in there...Just a thought.
Old Sep 28, 2002 | 07:46 PM
I Cant Drive 55's Avatar
Go to your local racetrack and find out where the drivers buy their springs. You can buy springs in different lengths and strengths . Most stock cars that cant use the tube frame front ends in their classes are using the camaro/firebird front clips.
Old Sep 30, 2002 | 03:29 PM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
If you buy V-8 springs for the frt, it will jack up the frt end.
We put Eibach prokit springs on my car and it raised it higher then factory springs in the frt. So we cut off half a coil in the frt. I would not recommend cutting stock springs as they are not progressive and removing any material with cause you to bottom out. The Eibachs are still performing well after being cut. We cut it with a cut off wheel to keep the heat low as to not effect the temper. Now the frt is slightly lower then the rear, but it is hardly noticible.
Attached Thumbnails Idea... lower the front of you 6 with springs...-field-side.jpg
Old Sep 30, 2002 | 03:56 PM
Camar_Hunter_c's Avatar
Why not just buy V6 lowering springs? they do make them afterall.
Old Sep 30, 2002 | 05:01 PM
Xenodrgn's Avatar
I never said to put V8 lower springs on the front... :grr:
camarohunter... havn't seen them...
Old Sep 30, 2002 | 05:08 PM
No I did read the posts in here. They make a complete set of V6 LOWERING SPRINGS they lower 1" .
Try going to google. suspension technologies. if I am not mistaken...
Old Oct 1, 2002 | 09:09 AM
redraif's Avatar
Sorry if I took it off a bit. I was more commenting on this comment, but did not quote it the first go around. Sorry!
At the time I got my springs, we had had no luck finding v-6 spings. That why I took that route.
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
Street Lethal
Aug 14, 2015 08:25 PM
