Cam Question
Old Nov 14, 2002 | 12:39 PM
CC_HotRod's Avatar
Car: 1984 Camaro
Engine: V6
Transmission: 700 R4
Cam Question
I was looking through the Summit and Jegs catalog at the Crane cams last night and noticed that they give two different specs for the same cam. Jegs is giving adv. duration 264*/274* and gross lift .423"/.423. Where as Summit is giving 204*/214* and gross .423"/.423". Those of you who have the cam which Duration numbers are right?
I have also been thinking about going to the Edelbrock intake for my Camaro and they make a cam that the Duration is 204*/214* and the lift is .420/.442.
Which cam do you all think would be best the Crane or the Edelbrock?
Old Nov 14, 2002 | 01:11 PM
DAN_92RS's Avatar
Car: 92 camaro RS
Engine: 3.1L v6
i din't know that edelbrok made an intake for our cars i'm thinkin about changin my cam too since i half to change the waterpump
Old Nov 14, 2002 | 01:20 PM
loomdog32's Avatar
Car: 82 Camaro Z28
Engine: LU5 - Crossfire 305
Transmission: 200c - 3 Speed Automatic
there are 7 different cams made by crane for the 60* v6.. http://www.cranecams.com/master/apps/chevy1.htm
ive heard that the edelbrock cam/intake together is better than a edelbrock intake/crane cam setup, but i dont know for sure on that...
-mike (loomdog)
Old Nov 14, 2002 | 03:59 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
I can't see how changing the waterpump, and the cam are even in the same league.
I change my waterpump in like 30 minutes or so, the cam is going to take a day.
If you were changing your timing chain, then changing the cam would go hand in hand.
Old Nov 14, 2002 | 04:33 PM
DAN_92RS's Avatar
Car: 92 camaro RS
Engine: 3.1L v6
my fault i'm still learnin about cars and i thought u had to take the water pump off to change the cam
Old Nov 14, 2002 | 04:37 PM
Joe_L's Avatar
Car: 1995 Z28
Oh okay,
Didn't mean to chew on ya there. I was just wondering what made someone think that waterpump and cam were in the same league thats all.
Old Nov 14, 2002 | 05:30 PM
Camar_Hunter_c's Avatar
cams, I would go to Crower(personal fav) and they come with just about EVERYTHING short of the valves.
Old Nov 14, 2002 | 05:55 PM
V6camaroman's Avatar
i recomend the wolverine blue racer camshaft. i have that im my bird. works great. terrific power increase. the specs are 204, 214 duration and .420, .443 lift. its beefier than the comp cam.
Old Nov 14, 2002 | 10:25 PM
CC_HotRod's Avatar
Car: 1984 Camaro
Engine: V6
That is what I figure. That edelbrock would make there compents so they work better together.
beastin91rs
Oct 9, 2015 07:38 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
