Does anyone else's 3.1 do this?
Old Nov 21, 2002 | 12:26 PM
91RSGYEA's Avatar
i have a 91 RS 3.1, a couple of my friends have one also, we were messing around last night talkin about burnouts n such and i was talkin about power braking in my car.....and they both told me it wouldn't barely spin how they had to drop it in first to get it to do anything....so we took they're cars out first and sure enough they could barely spin in first then we took mine out and i left it in drive pressed the brakes gave it half throttle and it'll smoke it up......what's different with my car? as far as i know it is bonestock.......any help or comments would be appreciated
Old Nov 21, 2002 | 01:39 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Slightly modded, all external bolt ons. The Mrs has no probs doing some . When I was doing repairs to it, trying to find out some clunking noises, I left some nice ones out in the road infront of the house Opps.
Old Nov 21, 2002 | 01:53 PM
SAEspinz80's Avatar
Yea, a friend of mine's 3.1 Camaro had a hard time doing too! But My 'bird has never had a problem. And with my mods I have even done some monsters ones with me and three other guys in the car. BTW, she's @ 115,000 now.....bought her with 72,000.
Old Nov 21, 2002 | 02:20 PM
91RSGYEA's Avatar
yeah but i have no mods.......my baby has 128,000 on her and is surprisingly running strong think the timing chain is going out though......well thanx for the replies
Old Nov 21, 2002 | 03:57 PM
camaro89dude's Avatar
my 2.8 never had any problems...but my friend's 79 3.8 engine with 0 torque couldnt even power brake. Our 160 lb/ft of torque make powerbraking pretty easy.
Old Nov 21, 2002 | 04:11 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
91RS...the 3.1 motor has 180-185 ft lbs of torque, while the 2.8's have 160...so that could account a tad bit but I doubt it. I can't imagine why they wouldn't be able to powerbrake it...unless they've got modifications that robbed their low-end power. Running oversized exhaust and certain other things will do that. Could also be from bad front brakes not being able to hold the car still. Half of it depends on whether you give it gas slowly or if you punch it. If you punch it, it should be able to spin regardless! My car will spin like CRAZY..like spin so the speedo is reading 40+ (when it actually works)...can do it in 1 or Drive. Once I did it through first and second gear...wasn't too smart but I gradually released the pedal so it was a smooth transition and didn't damage the tranny.
Old Nov 21, 2002 | 08:44 PM
elevario's Avatar
Car: 1992 RS
Engine: 3.1L V6
There must be something truly wrong with your friends cars if they can't spin their peg leg. Is it really that bad with an auto? All I have to do is punch it and I can spin first, second, and part of third anytime I want. It's not like your friends have posi or anything. Unless they put a unit in. I would love to! No more wearing out one tire before the other!
Old Nov 21, 2002 | 08:49 PM
Nixon1's Avatar
Yeah, I was thinkin the same thing elevario...unless they're just dumb...? I'm sick of peg leg too. My drivetire is now a racing slick, where my left side is halfway between a slick and a Radial T/A. Fronts are about the same..I need new tires!!!
Old Nov 21, 2002 | 11:12 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
When i first got my car i coulnt do a burn out at all i got new shocks in back and was able to do a burn out bone stock. I still can do a burnout and i have 215,000 miles on my 3.1
Old Nov 22, 2002 | 12:16 AM
SomeDodgeGuy's Avatar
I've only had my car since tonight. 3.1 V6 with 105k miles. No problems lighting them up in first.. sometimes I can bark in second, too.
And it has awesome tires.
Gotta stop with the harsh driving.. hehe.. gotta make sure its strong enough to put up with that punishment.
Old Nov 22, 2002 | 03:56 PM
pontiacguy1's Avatar
I swapped in a posi disc brake rear into my 1992 firebird 3.1 liter auto. I used to have 225-50 R15 tires on there, and i could bark them from a stoplight, just by hitting the gas, no brake needed. The tires wore out and I upgraded my rims to a set of 1985 TA 16X8 inch units wrapped with Kuhmo Ecsta Supra 245-50-R16 tires. Now it won't spin at all unless it is wet. The tire's width, diameter, and the amount of traction that a tire has will definitely change what it will do. I could bark mine all the time with the older, smaller, cheaper tires. These new ones stick like glue, though.
Old Nov 22, 2002 | 06:30 PM
Berlinetta's Avatar
You guys know what the definition of posi-track is?
posi-track= Replacing two tires every six months instead of replacing one tire every six months.
Old Nov 22, 2002 | 11:57 PM
zer0321's Avatar
yeah, but at least you look cool when you're doing it.....
and personally, i'd rather replace 2 tires at a time...
Old Nov 23, 2002 | 02:00 PM
Nixon1's Avatar
Yeah, I never replace only one tire. I do 2 at a time. And POSI is just plain cool..gives a better launch too. Not to mention gets rid of those embarassing pegleg tirespin launches.
Old Nov 23, 2002 | 08:08 PM
1986CamaroSC's Avatar
Car: 1986 Camaro SC
i had no problem in the 2.8 all it has is exhaust. the rest is bone stock, probably half original
you have to click "Save Target as" to see the movies..
http://86camaro.tripod.com/burn.mpg
http://86camaro.tripod.com/burn2.mpg
<img src="http://images.cardomain.com/installs/192000-192999/192436_76_full.jpg">
<img src="http://images.cardomain.com/installs/192000-192999/192436_103_full.jpg">
Old Nov 23, 2002 | 08:16 PM
Nixon1's Avatar
....why did you leave two tread marks? POSI or luck?
Old Nov 23, 2002 | 09:11 PM
Car: 1986 Camaro SC
I most always leave two marks, in the video you can see both spinning
Old Nov 23, 2002 | 09:20 PM
Nixon1's Avatar
You gotta have a posi rear..... I can BOIL my drivetire all day..like 100 ft treadmark....like it's nothing at all...but I can't get my non-drive tire to spin for more than a second or two even with oil covering the road and the tire!! It just won't do it...
Old Nov 23, 2002 | 10:27 PM
Car: 1986 Camaro SC
sweetness!! some ppl said i may have a limited-slip differential. maybe its true? that;'d be kick *** man
Old Nov 24, 2002 | 03:28 PM
Nixon1's Avatar
Yeah..there's no way you should leave treadmarks like that without POSI. Here's a real POSI test for ya. Take a 90 degree left turn and about halfway through the turn, floor the gas...(works better with a stick because of the quicker response)...but on a non-posi rear, you'll kinda whip....with POSI, the reaction tends more towards doing a complete 180. Yeah, it's a tad dangerous..lol..but it's another way to tell! There's a way too when the car is up on a lift to like spin one of the tires or something..depending on what the other does, that'll tell you..I think the other tire should spin the opposite direction but don't quote me on that.
Old Nov 24, 2002 | 03:47 PM
Car: 1986 Camaro SC
the 2.8 is dead now and it is sitting in a garage for winter, but wheni did a left turn and slammed the gas, the tail would begin to slide pretty good until i let off the gas, and the first day i drive it i almost did a 180 in the middle of the road off a left turn except that i slammed on the brake when i was horizontal, so maybe it is
Old Nov 25, 2002 | 08:10 AM
the next time you have the rear of your car off the ground, put it in park, or 5th if you have a stick, and try to spin one of the tires. If the other one spins the opposite way with only a little bit of resistance, you have an open differential. If you can't spin either tire, then you have a limited slip differential. The open differentials are what came in the V6 cars, but someone may have special ordered one, swapped in a different rear end, or who knows what else. My car was originally a 3.23 geared open differential. It'd be cool if you do have a posi unit in there.
Old Dec 7, 2002 | 04:38 PM
badandy247's Avatar
Car: 91 Camaro RS
Engine: 3.1L V-6
Transmission: Fresh 700R4
My 91 usually leaves two tracks, one not as long as the other but usually both
new transmissions are good!
beat my brothers 95 3.8 mustang we both have exhaust and nothing more he has a 5sp and my auto took him all te way to 120 he can't even go over 115 that shut him the hell up
Old Dec 7, 2002 | 06:45 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Does anyone else's 3.1 do this?
I would not be worried if my car couldnt burn out unless it was real slow.
now what happens when you two race??? who wins.
If he wins, his car is better, nothing wrong with traction.
matter of fact you never want you car to spin the tires, spining tires gets you no where fast.
now if you kill him ever time you race and he still cant burn out, his motor is tired. plain and simple. they get tired, still run but lose lots of a$$.
Old Dec 7, 2002 | 06:51 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
yep most times only thing a mustang will do is get your laid, girls love them shiny things that go vroom vroom. I know two guys who boulght black ones for that reason and both were a hunks of s[h]it, but it was shiny and went vroom vroom, and they got lots of tail out of it.
Old Dec 8, 2002 | 10:53 AM
badandy247's Avatar
Car: 91 Camaro RS
Engine: 3.1L V-6
that was why he bought it didnt really work out for kim too well though (maybe the girls saw thorough it or maybe they would rather get it in a thirdgen) but he constantly told me he could take my camaro so one night i decided **** it lets go do this an see once and for all who is faster
mustangs suck camaro tailpipe
Elephantismo
Feb 13, 2019 12:51 AM
cking99
Sep 22, 2015 11:33 AM
the_nikfive
Aug 11, 2015 02:46 AM
guy76767
Aug 6, 2015 05:58 PM
